Question about Dell Dimension 2350 PC Desktop
My computer comes on and then immediatley shuts off the starts the process over. Doesn't have time to even try to boot.
  • 106 Answers
1.Processor may be overheated,because the processor fan may not be rotate.
if processor fan is rotating then...
2.Remove the Hard disc power connector and data cables then try to on the computer.
3.Remove the Cd/Dvd drive power connector and data cables then try to on the computer.
4.Remove any other drives connected with your computer.
5.Remove the printer,scanner,mouse,keyboard connected with your computer.
thank u .... now u can find the problematic device. All The Best...
Posted on Apr 22, 2010
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
Tip
Quick Tip: How to correctly shut your computer down
This may seem like a simple tip, it is, however it can cause many unneeded problems to your computer if you do not shut it down properly. Do Not shut down your computer by pressing the power button. Whether you have a PC or a laptop, don't use the button. When you go to shut your computer down go to start and shut down and it will shut off. If you do not do this correctly it doesn;t give your computer the proper amount of time to shut down, you can corrupt your Windows files and eventually have problems even booting your computer up. Simple solution that will avoid future problems! Hope this helps!
Lori
on Oct 18, 2010 | Computers & Internet
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
Dell demension 2350 shuts down after a couple minutes what is wrong?
The most likely situation is a file error in the windows boot up process. Try booting the computer in safe mode (press the f8 key after the post screen, and selection menu will come up, sellect safe mode). If it does not boot this way, you could try a boot repair (since you did not list tthe brand model of computer, it is hard to direct you on this course). Most likely you will have to do a full restore to clear the error. This of course will remove all software, data that was not installed on the computer out of the box.
Feb 08, 2012 | Computers & Internet
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
E- computer turn on then the screen says it was shut off improperly. say click to restart or wait.....did this it ran through its process and went to screen with no signal. ran it again under boot and...
looks like it's stuck in a startup loop, can you boot from a windows cd into repair console (press R to repair with xp, choose repair my computer with vista or 7) ?
if so, type the command fixboot and after that fixmbr, if it still doen't work, try the chkdsk /F /R
command. if that doesn't work, try booting in hirens boot cd (download v13 and burn it to a cd rom) if still no success, you need to reinstall windows, if that doesn't work, replace the harddisk and reinstall.
Jun 17, 2011 | E-Machines eMachines Desktop PC
sounds like your windows installation took a hit, try booting from the windows cd into the repair console and do a chkdsk /F /R; a fixboot and an fixmbr command. if ths doesn't work, try the repair option. You can also try to boot from a hirens boot disk and try the tools that come with that.
The computer doesn't start windows is like getting
you are going to need to reinstall windows or try to unplug any unnessesary usb attachments then try to restart
May 07, 2011 | Microsoft Computers & Internet
Cant turn on computer starts up but then immediatley shuts down
Try F8 at boot to make it boot into Safe Mode. If it runs okay in Safe Mode and the device manager shows no issues, then Windows may need a repair/restore run on it. If it still shuts in safe mode, it may be a power supply/battery issue.
Sep 02, 2010 | HP Pavilion dv6000z Notebook
When i shut the notebook down and tryed to load it back up it will not load it gets to windows is staring and then restarts the process
Hi there!
Your computer may have an error that is causing the computer to restart, Try this one, when you turn on the computer start pressing f8, then advance boot menu should come up, after that select, disable automatic restart then the computer will start booting to windows then it should display the error, if it still stays on the screen q/o showing anything, do the f8 process again and this time select safemode.
Hope this helps!
Jun 01, 2010 | Computers & Internet
Dell Dimension 2350 PC Desktop Logo
99 people viewed this question
Alun Cox
