Question about Epson Stylus CX3200 All-In-One InkJet Printer
Noisy cx3200. grinding noise and paper jams - Epson Stylus CX3200 All-In-One InkJet Printer
  • 43 Answers
SOURCE: ERROR SAYS PAPER JAM
Its already a hardware issue. go to support.epson.com and look for a service center
Posted on Feb 02, 2008
Inky
  • 691 Answers
SOURCE: Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Posted on Feb 17, 2008
myob247
  • 1342 Answers
SOURCE: Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
Posted on May 11, 2008
doc_delphi
  • 11 Answers
SOURCE: CX11NF "Paper Jam" and Noise
Had the same problem, too. The grinding noise came from the gear of the loading mechanism, located (if looked on printer from behind) on the right side next to paper tray.
I had a problem with the paper loading, too.
That problem was due to a broken wire for the magnetic release of the loading mechanism, located on the right side, too.
My experience with this epson is, that most problems with it come from broken wires, e.g. the problems with the ADF I had, the problem with the magnetic release I had.....
If I hadn´t invested so much time and money in this printer, I´d rather scrap it immediately.
Posted on Sep 17, 2008
Mine use to do this, I changed paper type and it has not done it since. I was using recycled paper now I use HP All in One printing paper for Lasers and I do not have the noise.
Posted on Oct 17, 2008
I guess the pickup roller is stuck because I can't spin the green part of it. the printer has been noisy lately, with grinding noise and jamming paper often but today really got stuck completely. Can...
sorry bout the delay :(
the "grinding noise" only means that some parts/gears that is unfortunately inaccessible to users are either not lining-up or worst have loose teethes and ultimately causing the paper jams.
do you have any error from the LCD panel display? what number or code does it show?
refer to this guide:ftp://download.epson-europe.com/pub/download/289/epson28944eu.pdf#
if the issue is (obviously based on your description how the printer is performing) beyond what is shown in the guide above, go to the repair services section on this page:http://www.epson.co.uk/Printers-and-All-In-Ones/Laser/Epson-EPL-N2550/Drivers-Support#
that is one sturdy printer but sometimes paper jams initiates rollers and paper feeders mis-alignment that causes more paper jams and worsening the issue.
Jan 19, 2012 | Epson Epl-N2550dt Mono Laser Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Paper jams at front feed. noisy when starting. grinding noise
Run remove ink smears. Clean pick an feed rollers with packing tape.
Jul 27, 2009 | Xerox Phaser 8500/DN Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Noisy 4L
Did this occur suddenly or over a period of time it got worse?
Did it happen after a jam or other activity like replacing the drum?
Oct 18, 2007 | HP LaserJet 4L Printer
Epson stylus cx3200 paper jammed
if you look down where the paper feeds there is a roller as you pulled the paper back upwards out of printer you have forced the roller the wrong way you will have to push the roller round by hand it will click and clunk till it goes back into its proper location
Aug 20, 2006 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
