Question about Brother MFC 210C All-In-One InkJet Printer
I have a Brother MFC-255CW printer and cannot get a wireless connection. HELP?
SOURCE: Brother MFC-7840w wireless printer won't connect to network
For me, the quick solution was to use the 'Open System' instead of 'Shared Key', 'WPA/WPA2-PSK' or 'LEAP' authentication options on your printer.
However, after that, I decided to change the security settings on my router a bit. Log into your router, click the 'Home Network' icon at the top, and then check out 'Wireless Settings.'
The 'Wireless Security' section should tell you how your 2Wire is configured (which I eventually changed to WPA2-PSK.)
-DJ
Posted on Nov 15, 2008
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
MUKHTAR
  • 2017 Answers
SOURCE: My printer is offline how do I fix this
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also because you mention it goes off-line .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 22, 2010
SOURCE: I have a Brother MFC-7840w wireless printer. I'm
I will say i am above average in computer knowledge, i have setup many different issues with computers, but this was had me stumped. I have a BROTHER MFC-7840W win xp prof and i have to say calling BROTHER customer service was awesome.
For 2Wire users, at first I was very skeptical because of issues i was having, but once understand how works, kinda nice not having all those extra boxes and wires from modem and routers. Anyway, the key to getting this to work is to go out to the router, wireless and mac address open that up and uncheck the box enable. All 2wire manufacture's at least AT&T should have a further notation that all manual and WIRELESS additions of mac address must have box unchecked. Once i unchecked, honestly within 2 seconds printer was set up.
Posted on Sep 13, 2010
SOURCE: i cant print any documents
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Posted on Nov 25, 2010
How do I check ink level brother MFC-255CW?
Check the printer properties. If it's a network printer you can login to the web page for the printer.
Sep 07, 2014 | Brother MFC Office Equipment & Supplies
Mfc 7840w wireless printer through bell router
How do I connect a Brother MFC 7840W printer to a Bell Network. Every time I try to connect, I get a connection NG message on the printer. Any help would be greatly appreciated
Nov 14, 2012 | Brother MFC-8870dw Wireless Multifunction...
How to remove printhead in mfc-255cw
Maybe this will help to you
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_255CW_295CN_EN_1858.PDF
(section 4 page 5)
Jul 10, 2012 | Brother MFC255CW All-in-One InkJet Printer
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
I already downloaded the drivers needed at brother.com, but still can't install the printer MFC-255cw) on windows7
It is possible that you have the wrong driver package.
Here is the link you need to download and install the MFC-255CW on Windows 7
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/004000/dlf004002.html?reg=us&c=ca&lang=en&prod=mfc255cw_all&type2=1&os=92&flang=8&dlid=dlf004002
Make sure that you choose "save" to download the file; I recommend saving it to your desktop.
Once the download is finished, you will want to double click to run and decompress the file.
You should now have a folder called "mflpro_c1"
Open that folder and then open the folder corresponding to your printer (mfc-255CW)
Now you will see multiple folders with a setup dile at the bottom, run the setup.
If the printer is to be connected wireless, please make sur the wireless connection is completed before installing the software.
Thanks,
Pat
Apr 09, 2010 | Brother HL-2040 Laser Printer
My Brother MFC-255cw system says that it's connected to my wireless network, but when I go to search for it to connect it to my computer, my laptop is unable to locate it. I've followed all of the...
Try first try connect the printer using the USB and check on the printer if you have an antenna that need to be pulled out as some have them, the software as self diagnostic run it and see what happen and let me know if you get any error…Hope that help you and please do not forget to rate my service to be able to improve on it and help everyone.
Sep 19, 2009 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
343 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
