Question about Canon PIXMA iP90 Mobile Printer
The Canon iP90 printer is not printing any PDFs. It does print word docs though. Now what is this? Tried cleaning and all, but obviously this is not the problem.
Soulvisitor
  • 1113 Answers
SOURCE: print head for canon ip90
yes
6d8b426.jpg http://www.softwareforless.com/findspecs.asp?partid=52912B
Posted on Dec 29, 2007
SOURCE: Canon iP90 Printer Ink Issue
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Posted on Jan 03, 2008
SOURCE: Canon C3220 PDF print problems
http://www.adobeforums.com/webx?14@@.3bca0e93/7
Posted on Apr 28, 2008
  • 76 Answers
SOURCE: Figuring how to install new print head in my Canon iP90 printer
when you open the top cover, the carriage unit will mvoe to the middle of the unit. Once it is there hold the inks and move a bit to the left so you can see a grey lever. then the printhead and the inks will come up together. remove inks and replace head.
This should work for you
Posted on Oct 20, 2008
getbharti
  • 33 Answers
SOURCE: how do I force printer to use color cartridge to print B/W doc?
From the printer's front panel , look for settings or Rench Icon, browse it and look for the option clor management. May be it cud help u..
Posted on May 08, 2009
Canon pixma ip90 printer is not printing blue colours. i've tried cleaning but it doesn't work.
If the blue ink cartridge is not empty, then it means that either the pront head or the ink cartridge is clogged. Here are some information about ink cartridge cleaning, and here you can find some information about print head cleaning.
Nov 24, 2010 | Canon PIXMA iP90 Mobile Printer
Canon ip90 4 blinks error
4 blinks is a purge unit error, that's the device that the printhead parks on on the right. Could be just a paper scrap inside, or the gears are worn out. The replacement includes the entire print engine and costs more than a new printer to replace.
Sep 19, 2009 | Canon PIXMA iP90 InkJet Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Won't print black
same thing happend to mine. Have not sorted the problem yet but you can get it to print if you change the Ink usage settings. Go into your printer properties, select maintenance tab and click on the Ink Usage Control button.Tick "Use Composite Black" then ok. This will enable you to print out your docs at least.
Nov 08, 2006 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
23 people viewed this question
old marine
old marine
