Question about XO Vision 12.1 Flip-Down Monitor w IR"
I have a titanium power flip down monitor and its showing everything oppsite. it should post to show everthing left to right bbut it shows right to left
Has power but won't show a picture
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 880 posts to different brand TVs now.
Oct 01, 2012 | Mitsubishi LDT461V 46 LCD TV
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Screen lights up and goes back off with power still on. Ex.: When powering up computer, screen will show page for a few seconds then disappear untill a differant page comes up, show new page for a few...
Hi Larry,
I see that you are having issues with you LCD monitor intermittently showing Video for a few seconds then just dies to a black screen and will show windows in the desktop then go back to a black screen again on the issue ...
I believe that what you are experiencing on the issue is a screen refresh rate setting in windows.
we will need to check you video settings on the system for the issue.
Before we go and change some settings on your system we will need to boot into safe mode first.
1. From Shut down as soon as you turn your system on keep on tapping the F8 key on-top of your keyboard, this will give you the Windows Advance Options Menu.
2. On the List Select Safemode once highlighted press enter once, a bunch o things will show up on the screen this means that windows is loading in Safemode and windows will be loaded but all drivers will not so may encounter a screen that has big Icons and letters on it which is normal.
3. Log-in you windows profile if you have a password setup, once logged in do the following instructions below.
Changing the Screen Refresh rate:
1. Right Click on your Desktop/wallpaper to get the pop up options menu, click on personalize.
2. In the personalize window click on display lower left side of the window
3. Then Upper Left side of the new window click on Change Display setting then on the next page lower right side you will see Advance settings click on it.
4. you will get a small window click on the monitor TAB you will see there a drop down for the Screen Refresh rate click on the drop down and select 59 Hrtz, then Click on Apply then OK to save the settings work on your monitor.
Apr 06, 2011 | Computers & Internet
My webcam shows up as upside down. Looking for a solution.
Please go to the webcam settings. There you will have an option to MIRROR the image either vertically or horizontially. Try them both. The vertical flip will solve your problem and horizontal flip will turn your picture from right to left and left to right.
Feb 08, 2011 | Computers & Internet
Power shuts down
Sounds like a power supply issue.
If you call intex and tell they you have a power supply problem and a reciept within two years. they should ship you a new one.
Jun 23, 2010 | Intex '10 Saltwater System Pool...
Do you have the instructions for dokapon?
Hi....here it is:
Gameplay Controls Printable View Dokapon Kingdom GAMEPLAY CONTROLS:
wii_dir.gif Control Pad Move. Move Cursor. Up = Magic (Battle). Left = Strike and Counter (Battle). Rock (Roshambo). Down = Skill (Battle). Give Up (Battle). Scissors (Roshambo). Right = Attack (Battle). Defend (Battle). Paper (Roshambo). wii_a.gif A Button View Shortcut. View Space. Open Help Menu. wii_b.gif B Button Bag Shortcut. Display the World Map. wii_1.gif 1 Button Cancel. Movement Shortcut. Data. Show Information. wii_2.gif 2 Button Make Selection. Confirm Message. Stop Spinner. Show Available Moves. Speed Up Cursor. Show Predications. wii_minus.gif - Button Flip Page. Switch Between Opponents. wii_plus.gif + Button Data Shortcut. Flip Page. Switch Between Opponents.
Aug 05, 2009 | AIA Dokapon for Game Boy Advance
The left half of my desktop shows half of the picture
try replacing the video card. if the video card is working just fine then try replacing your monitor
Jul 02, 2009 | Dell Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power button on my 360 puts the one green light on the right instead of the left
I have a very similar problem I had a few days ago. But what I did was I shut down the Xbox 360 console completely. Then I unplugged the power cord from the Xbox 360 console and the wall outlet, and then I disconnected the batteries from the wireless controller. let it sit for about 5 min. Then plugged everything back in, and finally I hit the the wireless connecting buttons on both the Xbox 360 console itself, and the wireless controller(s).
And from then on, I have had no problems, what so ever since I did that (above).
Jan 05, 2008 | Microsoft Xbox 360 Console
XO Vision 12.1 Flip-Down Monitor w IR" Logo
97 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
