Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Where is the drain tube located on a roper refrigerator model rt18dkxkq
  • Roper Master
  • 8,220 Answers
where is the drain tube located on a roper - 895fab7.jpgRight there where the pointer is, backside of freezer
Posted on Apr 22, 2010
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
well unfortunately it sounds like a capillary tube may be stopped up and u may have to call a tech sorryi cant help more
Mar 01, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 10, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Frige icing up every 1 or 2 days roper
Hi, more then likely it would be the defrost timer that is causing you're problem. On some models they are located at that back bottom corner, mounted with a couple of screws.If you can't locate it, look at the schematic on the back and look for DFT and locate it from there. This will be the problem. Defrost timer failing.
Best of Luck,
Shastalaker7
Nov 24, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Freezer leaks. Into freezer and refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My Roper model #RT18AKXKQ05 is leaking water into the refrigerator from the freezer via the part in the back of the freezer. I can't find any help in the Use and Care Guide? What do I need to do in order...
it sounds to me like the drain is plugged in the freezer. When the freezer goes into defrost the water vapor gets pulled up by the fan and blows into the fresh food side via the air baffle in the back of the fresh food side. Take the back cover off the freezer and break up the ice and pour some hot water down the drain and if you have a small hose to shove down the drain and that will help you out as well...good luck!!!!
Oct 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Not draining
Most likely a clogged drain tube. Blow it out with compressed air. This needs to be done preiodically since dust tends to clog these tubes.
Aug 02, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Water dripping down inside from bottom of freezer
clean the drain line out,its a tube on the back of the refridgerator
Apr 26, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper refrigerator--water accumulating in bottom of fridge
on some refridgerators the plug at the bottom inside either turn out or lift up,be gentle either way,probably plugged just under it
Apr 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
298 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
