Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Deck blade on driver side is lower why
Is the lawn mower suppossed to have a lower cutting side or is there a problem
  • 23 Answers
Never heard of that sound like problem to me.might have lost a hitch pin in the mowing deck which has caused it to drop on one side or end
Posted on Apr 22, 2010
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
May 10, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
May 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
112 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
