Question about Maytag Washing Machines
Need a schematic to connect a motor on a maytag performa
  • toronjo1128 Apr 22, 2010
    i have the washer taking appart completly and there's not a schematic i need where the colors wire are going
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment about the model no# of your Maytag Performa so that I can assist you with the schematic.
Thanks
Rylee
Posted on Apr 23, 2010
  • 4,070 Answers
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Posted on Apr 22, 2010
  • Charles T Nevin
    Charles T Nevin Apr 23, 2010
    It's usually
    Washer-Dryer-
My Maytag Performa Washer is making a scratching noise during the spin cycle. Any ideas what it could be?
The problem could be due to few things.
1.There is a seal underneath the nut that holds the air bell housing on.
2.A faulty agitator component,there is a plastic hub that connects the
agitator to the motor and this can become worn.
3.Finally it can be the transmission,this is most likely your problem.
Apr 11, 2010 | Maytag Performa PAV2200
No power to maytag performa washing machine
You first hv to check whether your power outlet on the wall has power, with another appliance; check whether the power plug of machine is good, connections, fuse, etc. All good, then try below:
Plug off the wall socket. Open up the machine. Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. This normally works.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Feb 14, 2010 | Maytag Performa PAV2200
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
My maytag performa model number Pav 3200 IS SMOKING
Pump locked up Tip the washer over and take the belt off. try to turn the pump both direction. look for seperation in pump seal. Very easy to replace. Tools needed 3/8th nut driver. water pump pliers. pump is 30 bucks
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Maytag Performa PAV3200
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Maytag performa
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Aug 24, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
