Question about Konica Minolta PagePro 1390MF All-In-One Laser Printer
How do i mute the fax modem when sending a fax?
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
Sending a FAX
The fax is sent through the fax modem in your computer. All this printer does is scan the images for you and send them to your fax software which then dials the modem and sends the fax.
Apr 27, 2010 | Dell 924 All-in-One InkJet Printer
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
I give up. I have winfax software on this machine, but I am new at the job. Please can you help me link my fax to the winfax software? I am not able to send faxes as I think you actually have to be...
You need to setup a fax modem to be able to send and receive faxes with WinFax.
In WinFax, click on Tools, Setup.
Click on Modems & Communications Devices.
Here you can configure your fax device.
You need a fax modem, a DSL modem or a cable modem is not a fax modem.
I suggest you read this:
http://www.getfaxing.com/winfax/2009/06/25/first-time-guide-to-winfax-pro/
Jun 29, 2009 | Symantec Computers & Internet
Intermittent hangs with high fax volumes
Normally it would be as simple as queing and sending faxes but there are times when the problem is the line to the internet. If that goes very slow at some point during the send there is a chance that the modem will hang. Check if you are able to get on the internet with no problems for about an hour. How long do you notice the faxes going before it hangs. Also which actually hangs the third party software or the modem itself. You can test the internet by downloading a file see if it hangs up or becomes very very slow.
Sep 21, 2008 | D-Link DFM 562E (dfm-562e) Modem
Conexant data fax modem
preciso driver modem 56k pci v92 ami_cw
Jul 01, 2008 | Conexant v.92/v.90 PCI Data/Fax Modem...
Neto dragon v92 fax modem drivers
i have card neto dargon fax modem ,when i was formated couldn't work...
because this CD for fax modem was losted>>
so can send to my this file for this fax modem to install on my computer?
Jun 28, 2008 | Telebit Refurbished OPEN BOX EXTERNAL...
Cannot send or recieve faxes
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
Post back with your results.
Jan 04, 2008 | Computers & Internet
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Nov 08, 2007 | Computers & Internet
Konica Minolta PagePro 1390MF All-In-One Laser Printer Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
