Question about Lexmark T630 Laser Printer
Printer starts printing real slow after around 20 prints
  • 320 Answers
This problem will be fixed by changing the fuser. the thermistor has been comprimized. the reason the printer slows down is the regulation of the heat has slowed and the fuser is not heating fast enough to keep up with the demand. changing just thethermistor woulld fix it
Posted on May 26, 2010
Why did my printing rate suddenly slow down to about 20 Why did my printing rate suddenly drop to about 20 % of normal
Check the print quality settings in the Printer Control Panel. If set to best and color it will slow printing considerably and use ink much quicker. Draft and B&W printing is usually fastest and sips ink compared to other modes.
Feb 20, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Have Z2420 printer appears it's talking with PC says it's printing gives printing status as 20% complete but nothing prints s
It could be due to the print spooler service on your computer. Please follow the steps below on how to clear the print queue and enable the print spooler service.
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 15, 2012 | Lexmark Z2420 Printer
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
Printer will not print
I have the same problem nothing will print a need to print a fax report I need a confirmation.
Sep 02, 2008 | HP Officejet 4315v All-In-One InkJet...
Konica Minolta PagePro 1350W low print speed
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Jun 02, 2008 | Konica Minolta PagePro 1350W Laser Printer
Epson R320 prints REALLY SLOW!
That printer is known for being slow. If you believed a salesperson, they may have not done research either. But the printer is known for acceptable output for a really good price. Heres a review:
http://www.compukiss.com/populartopics/photoprintinghtm/review409.htm
Apr 08, 2008 | Epson Stylus Photo R320 InkJet Printer
Lexmark T630 Laser Printer Logo
407 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
