Question about Kenmore 62602 Electric Dryer
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
Kenmore 110.868738000 Electric Dryer Starts with noise for 10 minutes then stop. Once it stop, I can not push to start again. I have to wait for it to cool down for a long time, then I can push it to start again. Of course, it runs for about 10 minutes and stop again.
  • jt001j May 05, 2010
    I can not take out the motor blower.  It was a square shape, but now a round shape.  Cannot take it away the motor.  Any better suggestion?
  • Kenmore Master
  • 8,220 Answers
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Belt routingKenmore 868738000 Elect Dryer Starts for 10 minute - 8ec45fd.jpg
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Posted on Apr 22, 2010
  • Dan Webster
    Dan Webster May 05, 2010
    Here is my tried and true way. Lock down the shaft inside the dryer with a big pipe wrench or locking pliers or get someone to hold her down. Then go to the backside and insert a small hammer handle into the 3 o'clock position between two blades. Slam downwards with a rubber mallet and the blow will pop the blade loose.
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Hiow old is my Kenmore Dryer 110 62952 100 It has heat; starts to dry; then stops. Sometimes it finishes drying a load and sometimes not.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Kenmore 62802 Electric Dryer
I have an old Kenmore elect dryer model #86872100. When it starts in kind of sounds funny then after about 5-10 min. it starts sounding worse and then it just dies. You have to let it cool and then it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 27, 2011 | Dryers
I have a Kenmore dryer with Model # 110.C67711600 and Sr. # MU2206156. It is 2 years old and all of a sudden, dryer stopped drying. Clothes remain damp and wet even after running the dryer for 60-70...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Jan 02, 2011 | Kenmore 62622 Electric Dryer
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
401 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
