Question about Zanussi ZWF12070 Front Load Washer
My zanussi zwf12070 washing machine will not do anything. The start button flashes red three times and then turns green. The door opens but the machine does nothing. Please help. This machine is only 16 months old.
  • 269 Answers
If I am correct and 3 red flashes and 1 green then that is E31 which is normally a heater fault but can also be a faulty pressure switch or main programmer.This machine is covered by the 5 year major parts warranty.Does not cover the heater and it is normally the heater for that code.You can either get an Electrolux engineer to call out or your local service guy but be warned that only genuine heaters can be used on these machines they have safe fail fuse links in these elements.
Hope this was helpful.
Posted on May 05, 2010
Testimonial: "Thank you very much - very helpful"
Fabric conditioner dispenser does not empty
Hello Patrick Compton,
Start on PAGE 17 of your REGULAR MAINTENANCE...
in your owners manual... You are most probably looking at a MINOR MAINTENANCE ISSUE... in your dispenser drawer...!!
Else...
You are going to be looking for the valve... for your conditioner/softner dispenser...
CHECK out owners manual (below)
Look up you ORIGINAL parts number and get three estimates!!
Good luck
Hope this helps.
Zanussi ZWF12070 S1 User Manual
Zanussi ZWF12070W1 Washing Machine Spares
Zanussi ZWF12070W1 Washing Machine in White
May 22, 2016 | Zanussi ZWF12070 Front Load Washer
The washing machine has stopped midcycle and the start button is flashing red do you have any ideas of what may be causing this?
try to cancel it out and start again, if it won't cancel machine is telling you that something like belt broken or door open, etc.
Sep 22, 2015 | Zanussi Washing Machine Door Seal...
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
I have a Zanussi ZWF12070W1 washing machine. It's
Hope I can help.When you press the start button is there a buzzing coming from down by the filter if so Check that there is not something stuck in the filter.You will have to be careful depending on how much water is left in the drum so put some towels down and undo filter slowly or get the machine near a door then release filter out onto a door step.when drained shine a torch up inside filter and see if the little plastic blade on pump can turn but do not try and force it,if you do find anything in there then try it again and check the pockets.If there is still a fault you will have to call out your Engineer.
Good Luck
May 04, 2010 | Zanussi ZWF12070 Front Load Washer
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Zanussi ZWF12070 Front Load Washer Logo
696 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
