Question about Pinnacle Dazzle Digital Video Creator 90 (DVC90) [ Systems 210100371 ] (116352)
Have had a Dazzle fusion a long time but never used it til now. No external power supply needed (it says) but power indicator light does not come on. can't seem to transfer video from Samsung 8mm film camera. Any ideas? Thank you
4 Suggested Answers
SOURCE: Hollywood Dazzle Problem
One way I got past that (it sounds strange but worked for me). try playing the video from your device while iMovie is closed. Then open iMovie while the video is playing through the Dazzle and then try. iMovie seems to recognize whether its PAL or NTSC as it loads up. hope this helps
Posted on Feb 04, 2009
dDex
  • 145 Answers
SOURCE: my Dazzle DVD Recorder does not burn
Its a firmware problem.
Posted on Aug 13, 2009
iLovModz
  • 3 Answers
SOURCE: I need to replace the power supply on a dazzle dvc
That's a tricky one to find but you can live chat with a representative or call them at:
(650) 267 5196. Radio shack may also have an adapter.
Have a nice day
Posted on Mar 01, 2011
Given a dazzle pinnacle instant DVD recorder GmbH 2006 but only comes with windows software I have a Mac 10.6how can I get the software to make it go
There are different émulators for mac to run PC software Parallels Desktop , VMware Fusion, Apple BootCamp, CrossOverMac but those software are not free you have to buy them
Jul 22, 2011 | Pinnacle Dazzle DVD Recorder
My external lacie 500gb hard drive is not mounting. Its not spinning to mount. I need the data off of there. If i can get it to mount one more time i can transfer the data to another drive.
Try plugging it into different ports on your computer as well as moving the cable slightly on the drive. You probably have a loose connection somewhere on the drive so if you can get the contact it requires it should start up for you.
May 06, 2011 | Computers & Internet
I need to replace the power supply on a dazzle dvc 150 but I don't know the specs for the power supply.
Have a nice day
Feb 28, 2011 | Pinnacle Dazzle Dvc 150 (202261621) Video...
No power after power on and off. No power light indication. What could the problem be?
seems external power supply is shot try with another external power supply e-bay best shot,if power cord plugs directly in monitor then its internal psu might be cheaper to replace than repair
Jan 27, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
When i plug my dazzle in their is no picture only audio heres my setup: dazzle pluged in laptop other end of the dazzle i have 3 splitters in with both xbox cables and double sided av cables and then the...
HDMI Cables supply sound AND audio - there is no need to provide others. ie. if you have an HDMI OUT on the source, this should go into the dazzle and supply audio and video. If you try both it wont work. The AV cables from the xbox is to provide a source to an external audio amplifier/speaker system.
Have a look at this on Youtube, there are loads of set up videos.
http://www.youtube.com/watch?v=iO6rFmE7GQY
Regards :)
Dec 19, 2010 | Computers & Internet
System conflict created when I tried to fix a Dazzle problem.
I had a problem similar to this. I could not import from an analog camcorder. I tried the many solutions offered by Pinnacle and none of them worked. I have Windows 7, 64bit and Pinnacle 14 with a Dazzle capture device purchased December 2010. The solution for me was to reinstall Windows.
To reinstall Windows 7 ,first save all of your data files on an external hard drive. Then go to Control Panel/System & Security/Action Center/Restore Your Computer to an Earlier Version/Advanced Recovery Methods and select Reinstall Windows. After Reinstalling Windows restore all your data files and reinstall all of your applications. Then, update your application via the internet.
For next time, make a system Image under Advanced Recovery Methods and use it if the problem happens again.
Nov 14, 2010 | Pinnacle Dazzle Fusion/Analog video...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Indicator lights are blinking.
The Indicator Lights On The SC-X105L External Cam Are Blinking And Will Not Power Off. If both of the indicator lights on the external camera module blink and the external module cannot be powered off, this indicates that the batteries are in need of replacement.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Open Questions:
Pinnacle Dazzle Digital Video Creator 90 (DVC90) [ Systems 210100371 ] (116352) Logo
90 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
