Question about Pride Mobility Products Celebrity X - 3 Wheel Scooter - Candy Apple Red
Pride Celibrity 3 wheel electric scooter. The motor isn't working
When you press throttle you hear one "click" (solenoid I presume). The battery shows full charge. reverse or forward you just get a "click". With throttle pressed in you can push scooter without moving the lever on the rear wheel.
any thoughts.
thank you
  • 1 more comment
  • Scott Frye
    Scott Frye May 11, 2010
    Hi... When you turn it on , are there any blinking lights and if so, is there a sequence? I fix scooters for Pride
  • Anonymous Mar 22, 2014
    My scooter will no longer go into reverse, I can push it in manual mode but not drive it, forward is ok
  • Anonymous Mar 28, 2014
    rascel 329le scooter new batteries and service. scooter will just stop for no reson even with a full charge, if you flick throttle lever it may nudge forward or run at a snail pace, wat is the solution thank you. simon
  • 46 Answers
The click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Posted on Jul 11, 2010
I ordered a battery 5 days and it wont charge
I tried the DIY
service and repair manuals from a website and it actually helped me repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Mar 23, 2018 | Tablets & eReaders
Why can't i get my scooter to move it has full power.
Even though battery meter is showing full voltage, does not mean the batteries are necessarily capable of propelling the scooter. Have you had the batteries capacity tested? When you press the throttle does it beep or flash to indicate a fault? Is the solenoid brake clicking is it making any noise at all?
Jul 21, 2014 | Invacare Lynx Lx-3 Scooter Model...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Cle stalls when going to reverse to forward trailblazer 07 throttle body
I would check the idle control solenoid first. it is mounted near the throttle body or on it. When engine rpm drops it pushes the throttle open to keep it running. It also keeps idle up when switching on the
a/c and can be used as a quick check for the solenoid.
Feb 09, 2013 | 2007 Chevrolet Trailblazer
Scooter won't reverse and makes clicking sound by the controller by the electric motor
There is a servo which switches the transmission from forward to reverse and it needs replaced.
murf427
Aug 01, 2012 | Electric Mobility Health & Beauty
How do i reset my rc traxxas stampede?
I don't believe the reset (or syncing) is necessary on this model. However, on similar models you pull the batteries from the vehicle and the remote. Wait 30 seconds. Replace with fresh (or tested as good) batteries.
Best regards
Mike
Nov 20, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Charged battery on my blazer. Battery shows full charge. but when you turn the key you hear the fuel pump kick on but nothung else. doesnt even attempt to turn over?
Starter might be toast. If it clicks then it's your solenoid if it doesn't click the whole thing is pooched.
Or try putting it in Neutral and see if it will start.Maybe the safety switch is gone or broken.
Jul 28, 2010 | 1997 Chevrolet Blazer
2005 tuscon won't start turn the key there is silence the gear shift is locked up
Hi
Here is what you need to do.
Replacing The Stop Lamp Switch
Ignition off.
Remove the panel under the dashboard on the driver's side.
Removing The Stop Lamp Switch .
Press the stop (brake) lamp switch, from the side of the connector, completely forwards.
NOTE: A number of clicks should be heard and felt when pressing.
Disconnect the connector.
Press the brake pedal as far down as possible.
Pull the white bushing (1) as far forward as possible.
Press in the two locking lugs (2) on the reverse. Remove the stop lamp switch.
Thanks for contacting fixya.com
Oct 25, 2009 | Hyundai Tucson Cars & Trucks
Battery help
The clicking noise you hear is the starter. THe bike has a solenoid and it could be bad. Did you charge the new battery? The new batteries are filled at the shop and handed to you and you are told that is fully charged in 20 mins. Not true. Take the battery and trickle charge it for 5 hours. It should then have a full charge and start right up. If you still hear the clicking. The starter or solenoid are bad. Check all the wiring to the battery. Make sure they arent cracked or frayed. Making a good connection and no crud on the end of the wires. IF the wire to the starter is corroded. Replace it! Dont just clean it up. The wiring could be corroded up where you cant see it and this is why the battery is not getting the full charge to the starter. Hope this helps you out. TOM
Feb 15, 2009 | kawasaki ZX-9 R Ninja Motorcycles
Pride Mobility Products Celebrity X - 3 Wheel Scooter - Candy Apple Red Logo
455 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
