Question about Maytag SDG3606A Gas Dryer
2 dryer bars
Dryer bars inside my gas dryer fell off, (2) with one I get clumping clothes and plenty of wrinkles, fixable and expensive?
  • Maytag Master
  • 8,220 Answers
The bars are called BAFFLES P/N: 12002559
They are attached by 4 screws through the drum. You must pop the top to reinstall the baffles. Take one of the baffles to the hardware store and buy some good fitting screws. Then pop the top 2 dryer bars - 660ff1d.jpgand use a screwdriver to reattach them. Fairly easy to fix. IF you have the old ones. Do dry tennis shoes in there. Oopz LOL
Posted on Apr 22, 2010
Testimonial: "thanks, just a little too late though as I called repairman and now it is going to cost me $136.00 to put new ones on, because the screws tore it open"
  • Dan Webster
    Dan Webster Apr 22, 2010
    Don't dry tennis shoes my bad.
  • Dan Webster
    I was wondering why them thangs was so high. They sell 3 at the time
The clothing do not toss around the drum and the clothes come out in clumps and wrinkled
You may be over stuffing. Try smaller loads and see if you have better results. Too much stuff in the dryer means that your clothes will have less room to move around, and if they're all crumpled up in the machine, they'll come out, well, crumpled-up-looking.
Jun 13, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Moisture control
Dryers have 2 basic types: AUTODRY and Electronic. The electronic moisture control relies on 2 bars inside the dryer. As wet clothes rub these bars the wetness discharges the capacitor on the moisture control board. As long as the cap don't get a full charge the timer motor will not advance forward to the end of cycle. What goes wrong on these? Wax buildup on moisture bars form a barrier that keeps wetness off them bars. The control thinks them clothes is dry and shuts her down. On autodry the timer motor advances very slowly, The motor does not work while the heating element is on. Only when the heating element is off does the timer motor advance. As them clothes gets dryer the temp inside the dryer stays warmer and therefore the dryer thermostat keeps the heater off long and the timer motor advances. Like being on a highway with traffic jam you go a little bit then stop then go a little bit more then stop. Finally you get there. So what goes wrong? The control thermostat is not functioning properly causing the heater limit to do all the work . Instead the heater limit has to do the work and it ain't a real happy camper. Makes them clothes get too hot. They come out wrinkled.
Aug 30, 2012 | Maytag Dryers
Kenmore dryer will stop in mid cycle and beep 3 times in succession. What does that mean? Already had a repairman out and he replaced the circuit board.
Use some windex to clean the wax buildup off the dryer sensors under the filter housing inside the dryer.9bc0002.jpg Autodry VS electronic sensing: First, wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. (Auto dry dryers utilize a system of cycling the timer motor with the element, and has nothing to do with how wet the clothes are by the way.) There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel on many models. No sensing bars means you have auto-dry a totally different animal. Typically an orange wire is connected to the high limit on the heater element housing which feeds the timer motor when the element is not in operation. Bad control thermostat or air restrictions are the Autodry type dryer's worst enemy. Special thanks to a.g.
Jun 02, 2010 | Kenmore 63952 Electric Dryer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Maytag SDG3606A Gas Dryer Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
