Question about Schwinn Mesa Gs Mountain Bike
When peddling bike seems to try to shift gears
When riding the bike either the chain rides up or it wants to shiift gears. it does it more when it is under a load such as a hill. it does not shift gears when it does this but thats what it feels like.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
There may be some chain links that do not move freely. turn the pedal slowly backwards and check for siezed links, as it goes through the deraileur.
A worn chain can do this as well, unfortunately you usually have to change the chain and sprocket cluster as a pair. If you just put a new chain on a similar problem can occur.
Posted on May 03, 2010
Where can I find a manual for a Falcon adventurer bike? I haven't ridden it for a few years and can't remember how to work the gears
It means its an 18 speed bike. The shifting is easy. Start with the left side, begin riding, keep pedaling, don't stop pedaling in ther middle of a shift, it will throw the chain. As you ride, twist the shift grip, up and back. Still pedaling? Now after you have tried that one, try the other side, its the rear with 6 gears. Up and back, keep pedaling. After you have tried each individually, try them together. And now you're shifting. Looking good
. KEEP Pedaling
Sep 21, 2014 | Cycling
Regardless of what gear it's in, my Zike Saber chain slips as I step on the pedals. How do I solve this?
the saber zike is a elliptical bicycle. All answers above think you have a motorcycle or they have no clue. Is the chain on the sprocket, It seems to be off the gear. Zike recomends switching 1 gear at a time. Do not go from 7th to first gear in one shift or chain will come off the gear .It happened to me .Chain id not easy to put back on as a bike, that you can turn upside down and have it support itself on the seat and handlebars. The saber you must hold the back wheel off the ground and try somehow to turn the peddle backwards. I am not sure how to make an elliptical chain go backwards like a bike does without resistance.
Feb 03, 2014 | Cars & Trucks
Comfort 050 technology attachment catches the rear wheel spokes and causes the chain to come off the spokes.
Matthew, The item giving you trouble is the rear derailler. It works by moving the chain in (closer to the spokes) and out (further away from the spokes) so that the chain can climb onto the next larger or smaller gear. Yours is apparently going too far in when you try to shift to the largest gear. There are a pair of adjusting screws that limit how far in and out the derailler will go. Use this link to find some great repair help. Just click on the derailer on the bike in the picture. Good luck.
http://www.parktool.com/blog/repair-help
Aug 27, 2012 | Cycling
I have a 1984 Harley Davidson ,transmission problem:does not shift into 3rd gear after riding 25 miles.Just need some ideas what this problem could be.
Ok, we need to determine whether you have a transmission problem or a clutch problem. Ride the bike until it will no longer shift into third gear. Then stop the bike and turn the engine off. While rocking the bike backwards and forwards, try to shift the transmission though all the gears. If it shifts through the gears there, you have a clutch problem if it will not shift though all the gears, you have a transmission problem.
Please try this and repost with me. I need to know whether your transmission is a five speed or four speed. I seem to remember that those bikes had a four speed that year.
Let me know what you find.
Good luck
Steve
Sep 28, 2010 | 1993 Harley Davidson FXR Super Glide
While riding the transmission shifts uncommanded and clicking noi
Assuming the drive chain and sprockets are in good condition.(check these first)
This sounds like and internal gearbox problem, a bearing has collapsed or a tooth has broken of a gear.
Riding it like this will cause more damage. The gear box will likely need to be stripped
Jun 08, 2010 | 2003 Yamaha YZ 250 F
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
I have a moutian bike an the gears want change the back gears are slipping so i cant ride
Try this: shift into the highest gear and release the derailleur cable at the derailleur. Pull it taut and retighten the pinch bolt. Give it a thorough washing and degreasing, too. A clean drivetrain is a happy drivetrain. Remember to use bike chain oil, not anything else, on the chain and ONLY on the chain.
Nov 19, 2009 | Mongoose 2009 Firball 24" Boy's Moutain...
When im rideing the bike and cuming into 2nd & 3rd gears it feels like the gears are jumping or slipping and i dont know why this is
Either the shift cable is out of adjustment, the system may need lubrication, or the chain may be worn out. Try some light oil on the chain and shift mechanism pivot points. If it is the cable, try to determine if the bike shifts more easily to a higher or lower gear. Try turning the little barrel adjuster where the cable enters the shift mechanism a half turn counter-clockwise. If that makes it better, keep doing that until it seems good. If that makes it worse, go the other way.
Oct 01, 2009 | Cycling
When I ride my 18 speed bike the peddles ****, it feels like the chan came off, but when I look its still on how do i fix it
If your chain is still on the rear gears and the front gears on the crank and pedals to easily you have to switch gears into a combination that gives you more resistance. If you are unable to do this while riding, have someone hold the rear of the bike off the ground while you turn the crank and change the gear. You will generally want something in the middle of the rear gears and the second largest on the front to start.
Jul 15, 2009 | Cycling
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Schwinn Mesa Gs Mountain Bike Logo
185 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
