Question about RCA HD52W59 HDTV Projection Television
I can get a picture , but no sound on the TV . What am I doing wrong?
    Novelist:
  • 132 Answers
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
Posted on Apr 22, 2010
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
I have an 15" Curtis tv model number is LCD 1575! do I need a converter box? If not how can I make it work there is no picture or sound ??
A converter box for what precisely? And how long have you had this tv? No picture or sound may be a broken TV. It could also be that you have the wrong input source selected. What are some other odd symptoms, other that no picture or sound. What exactly are you trying to do?
Jan 31, 2013 | Televison & Video
NO SOUND!! Our Dynex Energy Star TV is able to provide pictures on all stations, but the sound is not working. We have followed all the trouble shooting suggested but still no luck. The only sound we...
do you have a surround sound system connected to the tv or are you trying to just get your volume from the tv.if it's only volume from the tv check which input you are using to broadcast wheather it's set on catv or antenna or avr vcr .some tvs will allow picture without sound if it's the wrong setting.if your using satellite tv you may have your connection for your tv in on the wrong connection it will give audio or video without both .many main boxes on hd dvrs now you must connect the first tv correctly and flow from that.if it's direct tv and you have moved try reversing your number 1 and 2 boxes and then reconnect properly to reboot your addressable command
Jan 28, 2013 | Dynex Televison & Video
Picture and sound go off and power indicator blinks eight times. TV will not turn off or back on. Disconnecting power for a few seconds restores the picture and sound for a time, but then it repeats.
The TV might be telling you that there's something wrong with the power (wrong or excessive voltage, for instance). Please test the TV at someone else's house to rule out electricity problems at your house. If the TV still shuts off, then there should be something wrong with its logic board or power circuits, and you should call a technician to inspect it.
Mar 02, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture
check the cables it sounds like they are connected wrong do you have more than one input on the tv ? you can only run one of the devices at one time let me know
Dec 13, 2007 | Philips 34PW850H 34" TV
RCA HD52W59 HDTV Projection Television Logo
205 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
