Question about Kenmore 54501 Dehumidifier
Will my basement be drier the lower the control setting 35 is the lowest and 70 the highest.
  • 455 Answers
Hello,You are correct!The lower number reflects the RH% approximately in the aera you want.Lower number=drier air.RH=relitive humidity.
Posted on Apr 22, 2010
If basement has damp order what setting is better raising to 70 or lowering to 45
The lower the number the dryer the air will be. 50 will provide a comfortable room.
Aug 03, 2014 | LG LHD45EL Dehumidifier
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
I have an LG model LHD65EBL dehumidifier. The humidistat will not change from 70 when I push either + or -. The fan runs well and the compressor sounds like it is running well Some water comes out when the...
Prt of the problem may be a dirty or clogged air intake filter.
Turn the unit OFF and unplug, it before removing the filter to check and clean it.
You can ether vacuum it or if it's really dirty & clogged, wash it in warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow it to dry completely, before reinstalling it.
Never operate the unit without the filter in place. As this could damage the unit.
Plug the unit back in and turn it ON. Try lowering the humidity extraction level now, using the arrow down button. For a very damp, humid basement application 35% is a good setting to start with for several days.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD65EBL Dehumidifier
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Crosley Model # DCW405, spec.D40F-LCRF270. Last year the compressor would not kick in. I did some simple thing to get it to work. This year, i again cleaned the filter, plugged, unplugged, scooted...
It may very well be that you have the humidity extraction level set to high. Lower it to 32-35%. If you have a manual unit, set the control to Maximum. Since it's a basement application, raising the unit up off the floor on to a sturdy table or counter top that can handle the weight of the unit, plus a full bucket of water, may also solve the problem. As, the air temp at floor level is colder than at chest or shoulder level. Dehumidifiers do not work well at temperatures between 40 - 60 degrees F. Unless you have what's called a Low Temp Model. They are specifically designed for basement applications.
Hope this helped you to troubleshoot and solve the problem
Jul 03, 2011 | Crosley Dehumidifiers
Only the fan is running Thanks. Douglas Bisson..
Mr Bisson, there are several things that can casue the problem you have. All of which a usually solved very easily.
1. Dirty or clogged air intake filter. Remove and clean the filter per the manufacturer's instructions. Clean the filter once every two weeks, as part of routine maintenance.
2. The humidity extraction level is set to HIGH. Lower the setting to 35% or lower.
3. Obstructed air flow. Maintain a minimum of 12" clear air space on all sides of the unit, while in operation.
Any or all of the above can cause the problem and are easily solved. I hope this helps to troubleshoot the unit and solve the problem..
Jun 09, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifier keeps turning off is hooked up to hose no water draining air filter is clean. model #ld450eal 45 pint
The most common problem is that the humidity extraction level is set to high. Set it to it's lowest setting. If you have an LED screen on your unit, the lowest setting will probably be 35%. Or in the case of no LED screen, Minimal will be the setting you want to use.
Since you're using a drain hose, I assume the unit is in the basement. If that's the case, the ambient air temperature at floor level, may be to cold for the unit to operate properly. Most dehumidifiers struggle at air temperatures between 40 and 60 degrees F. Try placing the unit up off the floor on something sturdy that can handle the weight (including a full tank of water) and the vibration during operation.
Hope this helped you trouble shoot and solve the problem.Please let me know. Thanks.
Jun 01, 2011 | LG Dehumidifiers
What is the proper setting to take the moisture out of the basement?
The lowest setting that the unit shows on the LCD screen. Usually 35 to 45% is the best setting for a basement. However, if the ambient room temperature at floor level is between 40 and 60 degrees F, it may struggle a bit or the coolant coils may frost over a bit. If this is the case (air temperature,wise), get the unit up off the floor on to something that is sturdy and can handle the weight and vibration of the compressor running.
Hope this helped you. Please let me know. Thanks.
May 30, 2011 | DeLonghi DE500P Dehumidifier
A large block of ice formed over the entire front where the vent is. Basement temp was apprx 64 degrees F, but this model is supposed to operate at lower temps. Discovered after it was running continuously...
35 is way low; why not 50%?
At the cooler temp you may need to also run a small fan or space heater blowing on it.
It is working, but the setting is too low and the temp in the room is too low
Nov 25, 2009 | LG LHD65EBL Dehumidifier
Kenmore 54501 Dehumidifier Logo
76 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
