Question about Dishwashers
Dishlex DX302 dishwasher: cycle pauses and readout flashes "20" until program/clear button is pressed. This happens several times during a wash. How to fix?
  • Anonymous Mar 27, 2014
    Dishwasher start and after a minute or soit stops and nothing happens. What is the fix.
  • 1,512 Answers
Hi there
Is the machine emptying completely? It may have a blocked waste hose causing the drama
Posted on Mar 22, 2008
  • Graeme Ross
    Graeme Ross Mar 22, 2008
    The error code "20" means just that. The waste hose or bottom filter of the machine is blocked. If it connects up to a waste disposal unit then it may be blocked from gunk associated with that too. You may have to remove the waste hose from its drain connection and check to see if it is clear. I also suggest running a "cleaner" product through the machine now and then to keep this side of it flowing nice. Good luck
    regards Graeme
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My "3 Sec" button is
The control touchpads can be locked to prevent unwanted use. If this feature is activated between cycles, the dishwasher cannot be operated until the controls are unlocked.
The indicator tells you that the controls have been locked to prevent kids from messing with them.
Press and hold the "3 Sec" (control lock) button continuously for 3-5 seconds. That should clear the lock.Now you can use the controls normally.
To re-enable the control lock, press and hold the control lock button continuously for 3-5 seconds, until it indicates locked.
Dec 21, 2010 | Maytag MDB9100A Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My dishlex 760 cuts out during the cycle, there
I have the same problem.
Initially, the only problem was the dishwasher was not taking in water. Told to replace solenoid - which i did.
Now the problem is exactly as you explain. Sometimes you have to keep trying after 20 times and then it goes.
Any ideas on what the problem was ???
Mar 03, 2010 | Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwashers Logo
665 people viewed this question
Top Dishwashers Experts
