Question about Brother MFC 210C All-In-One InkJet Printer
Unable to clean brothers mfc 210c - Brother MFC 210C All-In-One InkJet Printer
SOURCE: vista and brother MFC 210C
download the driver click here
Posted on Jul 14, 2008
  • 7 Answers
SOURCE: Brother MFC-210C keeps displaying unable to clean messasge
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Was this solution helpful? Show your Appreciation by rating it:
Posted on Dec 02, 2008
  • 7 Answers
SOURCE: Hi, I have a Brother
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Posted on Dec 03, 2008
komguy
  • 2306 Answers
SOURCE: my brother MFC-210C says unable to clean,opened it
With no jam, it might mean that the ink absorber is full, Not an expensive part, but a shop needs to do it and reset the count.
Posted on Jul 29, 2009
SOURCE: Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Posted on Jul 31, 2009
Unable to clean brother mfc 210c
MENU * 2 8 6 4 8 0 2 7 8 3 and Mono Start. 9 9 to exit
Apr 24, 2014 | Brother MFC-210C Multifunction Printer -...
Brother 210C printer unable to clean
you need to replace ink pads and reset the ink pad count
Nov 19, 2012 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean printer
can clean the printer always say unable cleaning
My mfc 210c is unable to clean and therefore I
Unable to clean means the waste ink is full, about 1 hour labor and $20.00 part. With the new machines running about $100.00 it's probably not worth the repair.
Oct 26, 2009 | Brother MFC 210C All-In-One InkJet Printer
"Unable to clean" error message on Brother MFC 210C all-in-one printer.
reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine
Sep 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Jan 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
