I have a RCA L32WD14.... when you turn set on, the backlight comes on for a couple of seconds, green led is on, then set goes back off and a red led is illuminated. All of this occurs in a couple of seconds. Can you give me the most likely cause of this. Thanks Jeff
  • 7 more comments
  • jffryjrdn Apr 22, 2010
    Thank you..... on the set ,all you will see is the backlight come on for a couple of seconds, it may have sound or a picture if it were to stay on longer but it goes back off very quickly so the momentary backlight is all you see. Jeff
    Thank you ... this set does have a separate inverter board . Jeff
    Thanks.... I do have a dvm Jeff
    Thank you.. So i compare the 24 volts going into ballast board from power supply TO say, the voltage that feeds the lamps ,and then, determine which is lost first. I this correct? Jeff
    Thanks very much. You have been very helpful but it will be tomorrow before i can get this information. I would like very much to continue then if we can... if not thank you anyway.... I got started on this a little too late today. Jeff
    Thanks....EST same as yours...i'll have those measurements tommorow . I'll check with you around 4 ...Jeff
  • jffryjrdn Apr 23, 2010
    Thanks for helping.... I checked the voltage.... here is what the set does set comes on with green led & 24 volts & backlight on ,then in about 1 second backlight goes off , 24 volts still there,then in about 2 more seconds the red led comes on , then, in about 2 more seconds the 24 volts drops to zero .....Jeff
  • jffryjrdn Apr 25, 2010
    Thanks for your help...sorry it took so long getting back to you . Jeff
    No i did not have a time to check that , but i did get to check the 24 volts.... the voltage is there "before" you press the power button to turn set on. It will be monday before i can check the t-con board. What will it indicate if the voltage does not drop with this board unplugged? Jeff
  • 566 Answers
Hi jeff
I`m going to help you with your tv but first i`d like to know;
Apart from the backlight coming on , do you have picture and sound while it is on?
Posted on Apr 22, 2010
  • 8 more comments
  • Jacques Marin
    Jacques Marin Apr 22, 2010
    O.k did you open the back of the set ?
    I`m asking because there is two circuits that cause that problem beside the main board and that is the power supply and the backlight inverter board.
    In some models the p.supply and inverter are on the same board.
    So i`d like you to take a look and tell me the layout of your set.
  • Jacques Marin
    O.k the next question is do you have a multimeter ?
    I`m asking because the next step would be to take some voltage measurement.
  • Jacques Marin
    O.k so there should be some 24 volts going to the inverter board.
    What i`d like you to do is check if that voltage drops in the power supply before the inverter goes off.
    The idea is to find which board shuts off first.
    Those voltage are usually indicated near the output connectors of the power supply.
  • Jacques Marin
    What i`d like to find is ;
    If that 24 volts drops when the inverter board goes off.
    Or is there all along, even when the set is off.
  • Jacques Marin
    No problem jeff
    Should be back online at about 4:00 pm EST
    What is your timezone?
  • Jacques Marin
    o.k talk to you then.
  • Jacques Marin
    Jacques Marin Apr 23, 2010
    O.k then is the 24volts present on standby(no power switch activated) ?
  • Jacques Marin
    Also ; In the upper middle part of the lcd panel there is a small board(usually under a shield) called the lcd controller or t-con.
    I`d like you to pull the plug off (the one coming from the main board) to see if it makes a difference.
  • Jacques Marin
    Jacques Marin Apr 25, 2010
    Hi jeff, welcome back
    Did you try the t-con board ?
  • Jacques Marin
    What i want to find is;
    If the backlight stays on when the t-con is unplugged as the main board may switch it off when it detects a fault with the t-con.
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Rca L32wd14 has no pic or sound green power light just flashs ????????
It may be sensing short circuits in the power supply or in the backlight inverter boards, those are the two places you need to check first. Try disconnecting the connector from the power supply to the backlight inverter board to see if it turn on, you just will not have pictures but you should have sound.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | RCA L32WD14 32 in. LCD Television
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Model D52W19BYX2 RCA
Horizontal output and the low voltage regulators should always be checked first in a set that wont power up. If you need a manual go to http://www.servicemanuals.net/. Be sure to check back if you need some help.
Jan 05, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
