Question about Kyocera Copystar CS-1820 Black and White Copier
Papers keeps jamming in the bottom tray - Kyocera Copystar CS-1820 Black and White Copier
  • 165 Answers
Pull the tray out ull see a big gray tyre inside the copier clean it with wd40,and at the back of the tray ull see a green paper stopper make sure its right up against back of the paper.
Posted on Apr 25, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Jam in tray 1. Where is tray 1?
Hi, Kindly note that bottom Draw of the printer is the Tray 1. If the printer says Jam in Tray 1, kindly check if there is any paper struck in the printer. Remove the Paper from that Jam & your printer should work fine.
Feb 05, 2010 | Brother HL4040CN Laser Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper jam
The paper jams in the bottom because the leading edge hasn't reached the correct sensor in time, thus causing a jam message. Do a sensor test on the front panel of the printer before replacing any parts. Go into Diagnostics/Sensor test and you will see the letters across the top follwed by numbers below. Then you want to toggle the sensors located through out the paper path-usually black plastic hanging done into the tray areas. Up in output tray has black plastic hanging down-sensors. lift top cover and you can see the sensors on the left side of the top a black horseshoe shape is a sensor. This will help with the correct parts needed to be replaced.
Oct 02, 2008 | Toshiba TEC B-882 Thermal Label Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
RECURRING PAPER JAM - BROTHER MFC 5860 CN
I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
Feb 02, 2008 | Office Equipment & Supplies
Kyocera Copystar CS-1820 Black and White Copier Logo
100 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
