Question about Canon CanoScan 3000F Flatbed Scanner
Scanner does not respond to Scan, Copy or Email command. Attempt to copy using toolbox gave the following message: Error in scanner. Unable to open TWAIN source. Please check connection, the restart toolbox. Clicked OK and checked all connections, but negative result.
    President:
  • 1,851 Answers
Twain is the driver for the scanner. Have you tried to remove the driver and install it again? In any case you don't have the drivers if you need them, here is the location for you to select your language, operating system and download.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 22, 2010
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
Scanner cannpt communicate with laptop
try downloading the driver for the scanner as it may be corrupted or not compatible for the pc/laptop
Mar 05, 2017 | Canon CanoScan 4400F Flatbed Scanner
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
First time scanning
greetings.
To send copy of printed documents to others, follow the steps below.
1. use your scanner to scan your printed documents, save it to jpg format.
2. Use your email to send the pictures.
login to your email
compose or create the message
attached the images
send.
Hope that helps.
Jan 06, 2009 | HP Scanjet 4400c Flatbed Scanner
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
176 people viewed this question
old marine
old marine
