Question about Linksys Wireless-G WRT54G Router
Laptop not seeing router cable company shut off service by mistake, main computer has access but laptop does'nt I have a wireless G WRT5462 V1
  • 2,260 Answers
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Apr 22, 2010
How to set up a internent connection for 2 companies both with independent lines using a single broadband connections and DrayTek V2930VN Wirelss Router/Firewall with VoIP.
The easiest solution is to use a simple router (wired-only) to connect to your Internet Service Provider.
Run a cable from one of the LAN ports on the router to a wired/wireless router, to provide access for the first company's computers.
Run another cable from another of the LAN ports on the router to a wired/wireless router, to provide access for the second company's computers.
May 05, 2011 | Draytek Vigor 2930Vn Wireless N Router...
Everything was finewith wireless until we pluggd ethernet cord into back of siemens for xbox 360 now computer (wireess) doesnt work upstairs help
check what cable you plugged into the xbox...and be sure is not the main internet cord that it supposed to be in the wlan port of the router ...and get a cable from one of the router's LAN port into the xbox..and leave the main one into the wlan ..this way you will have wireless ...if the configuration on cables is ok ...get into the settings of the router from the admin computer the settings were made in the first place ....and see whats wrong with the wireless settings ..they may be disabled by mistake ..or another odd reason ...and enable the wireless transmitting again ..
Mar 21, 2011 | Computers & Internet
I have a LINKSYS model: WRT5462 V1 router and i have internet connection when i directly connect my laptop to my DSL machine. My laptop can detect the wifi signal but it says LOCAL ACCESS only. how do i...
Hi, First you have to configure the router. to configure connect the patch cable to your laptop, connect the other end to the #4 ethernet slot of the router. Open a internet web browser type at the address bar the IP address 192.168.1.1 the router will open and will as for user ID admin Password is admin or password. You can change the password of the router, SSID and security enable and use passphrase or key. I hope this information will help you solve the problem. Have a Happy New Year... HRH
Dec 30, 2010 | Linksys Wireless-G Broadband Router
I have a wireless G broadband router model #wrt5462 V1 serial number CSV01H269410. I cannot remember my password andneed to change it,
The only solution to recover your encryption passphrase or WEP key is to reset the router. Doing so will restore the router back to factory settings and clear out any settings in resident memory.
To do so, simply use a pen to push in and hold the reset button located on the back of the router (next to the power adapter connector) for 10 seconds.
Again, please note that this will erase all of your custom settings and restore it back to factory settings (like the day you bought it). However, from there, you can re-customize your settings and add your other computers to your wireless network.
Aug 11, 2010 | Computers & Internet
I am using linksys wrt54g2 V1 wireless router. The connection in wireless is fine. If I connect 1 wired coneection, it is still okay. But if more than 1 wired connection is used, all wireless connection is...
/Sometimes you have to call the cable company and they will reset the modem online for you. After you have done the whole powercycle bit, you have to restart the computer. Make sure all the other computers or laptops are shut off when you reset.
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters2.gif. Hope this helps!
Sep 18, 2009 | Linksys Wireless-G WRT54G Router
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
Cannot see other computers on my Zyxel router network
Change Settings, Be sure they on the same domain & workgroup settings and they are all shared.
Feb 27, 2009 | Zyxel P660HW-D1 Router
Connecting to wireless router
I wouldent to that , not that way! since they track all activity that passes the router they track your laptop aswell.
If i where you i would have bought me a 3G broadband dongel for my laptop. No one sees you, no one tracks you, and you can use it wherever you are and you are anonymus
Using a company router for private surfing is always risky, IF you by mistake surf to an infekted site, your company will all over you.
Good luck to you
Dec 19, 2008 | Linksys Wireless-G WRT54G Router
I have been using my laptop from work at home using my links router for about four months. my router is connected to my home computer. The cable company intenet service we used changed servers and my son...
Are you trying to connect the laptop using wireless? If so, you probably don't have the wireless settings from your router setup on the laptop. If you have a Windows based computer, click START => RUN.., type CMD, then hit OK. A black DOS window will appear. Type IPCONFIG and hit ENTER. You should see something like this:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.0.xxx
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Open your web browser and type in the address you see next to "Default Gateway" (in this example it's 192.168.0.1). This *should* be your router. Hit ENTER and you should connect to your router's web interface. From here you can find your wireless settings and match them on your laptop.
Laptops also usually have off/on switches for the wireless feature. Check to make sure you have the wireless card actually turned on. That is a simple mistake people make.
I hope this somehow helps.
Feb 17, 2008 | Computers & Internet
D-link dir 615 ; can't get other desktop to read wireless network
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G WRT54G Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
