Question about Gateway M-6827 Notebook
Gateway M-6827 LCD screen issue
Gateway M-6827 LCD screen appears frozen unless bottom right side is held.
HOW TO REMOVE MOTHERBOARD GATEWAY M-6827
I would check the power socket first. There normally is no fuse on the motherboard.
Oct 05, 2015 | Gateway M-6827 Notebook
HOW TO GET A MANUAL FOR GATEWAY M-6827 LAPTOP
Gateway has not written a manual dedicated to this laptop but they have written generic manuals G.
The manuals can be downloaded here
http://us.gateway.com/gw/en/US/content/drivers-downloads
- Select the Group Notebooks
- Choose series M
- Select item M-68
and click on Documents to see the list of manuals.
Jul 27, 2014 | Gateway M-6827 Notebook
Replace lcd on gateway NV57h77u
I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel.
(Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed.
Little round covers I believe to be made of plastic.
(Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them.
Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury.
Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky.
If you are careful with them, you should be able to reuse them.
If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges.
These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method.
Come to the inside edge of the Display Bezel.
Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it.
Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side.
Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose.
NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s.
Display Bezel can get hung up around them.
Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part.
Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
http://www.ebay.com/itm/Gateway-NV57H15U-LCD-Front-Bezel-15-6-AP0HJ00021-/171020787909?pt=LH_DefaultDomain_0&hash=item27d1a220c5
The MAIN view shown is a BACK view.
In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled.
You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers.
These layers are kept in the factory set alignment, by a metal Screen Frame.
The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame.
These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
The Brackets are an integral part of the Hinges,
http://www.ebay.com/itm/Gateway-NV55-NV57-LCD-Left-Hinge-Rail-Bracket-AM0HJ000100-/400334888754?pt=LH_DefaultDomain_0&hash=item5d35d19f32
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module.
(Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward.
The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
A) http://www.insidemylaptop.com/replacing-lcd-screen-on-gateway-nv57h13u-laptop/
B) http://www.youtube.com/watch?v=ENmPg46IB9Q
Apr 12, 2013 | Gateway Nv57h77u Laptop/notebook
How do I change the wireless card in my Gateway M-6827?
http://www.manualowl.com/m/Gateway%20Computers/M-6827/Manual/145833
Nov 11, 2012 | Gateway M-6827 Notebook
Gateway wont turn on
That would be a good idea scene it wont turn on you can try simple things like taking out the battery and holding the power button for 30 sec and see if it turns on if not take it to a tech.
Oct 02, 2012 | Gateway M-6827 Notebook
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
I have lines that appear on the monitor that started as a speck, then a line and now it appears extending from the bottom of the screen to the top. What is the cause of this and how can it be corrected?
Well, I have a 24 in Gateway. I unplugged everything from the screen, held the power button for 30 seconds, and plug everything back in. It worked again, apparently the problem was caused by a build up of static electricity and pushing the power button cleared out the static. Hope this helps.
Jun 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Black lcd display no backlight just very dim
The inverter should usually sit on the right side of the display. The thin black and white wires with the "appliance plug" on the end is held at the bottom of the display by one of the smaller screws. It fits onto the screw hole and is held by the screw at the bottom right/middle. The red/green/yellow/black/white set of wires is hooked into the display near the hinge and the other end is plugged into the board on the base unit of the laptop itself. Hooking the monitor back up is kind of a pain given the amount of parts/screws but it's more time-consuming than difficult. Good luck and I hope I helped some :-)
Feb 21, 2009 | Gateway 4530GZ Notebook
Thin yellow line on the right of the LCD Screen
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
LCD screen partially display's
This kind of issue is usually due to a loose inverter cable, re-seating the cable is a relatively simple matter.
If the laptop is still under warranty you should contact Dell to have it repaired, if on the other hand it is out of warranty you should shop around for a repair quote unless you are absolutely confident you can strip and reassemble your laptop.
Mar 13, 2008 | Dell Inspiron 6400 Notebook
Gateway M-6827 Notebook Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
