Question about HP Officejet 5610 All-In-One InkJet Printer
How do I use the scanner - HP Officejet 5610 All-In-One InkJet Printer
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Need scanner software for windows 7
If ou cannot get the Windows 7 scanner driver for your model scanner from the scanner manufacturer's WEB site then the manufacturer considers this scanner too old.
BUT you can get a scanner driver from this WEB site.
VueScan 9 scanner driver - compatible with over 1750 scanners
http://www.hanrick.com/
Dec 06, 2011 | Office Equipment & Supplies
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
Benq scanner model# 6678-9bz I have lost scanner cd I brought from jeddah kindly please send us Scanner driver above model to my email
benq scanner model# 6678-9bz I have lost scanner cd I brought from jeddah kindly please send us Scanner driver above model to my email
hadhuda1980@yahoo.com
Feb 16, 2010 | BenQ S2W 5450U Flatbed Scanner
Need Scanner Frequencies & Codes
Hello there:
here is a whole list of links that will get you what you need ok
I hope that this is very helpfull for you
Best regards michael
  1. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff! ... police scanners; general police scanner info, police scanner frequencies, live ... 10/03/09 - Police Scanner Frequency Resources (3 New Resources Added! ...www.police-scanner.info/index.htm
  3. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... Until the day internet becomes free to all, that is something that just cannot be ...www.angelfire.com/wi/scanner/frequency.html - Cached
  4. The Nation's Oldest and Largest Scanner-Only Dealer Frequencies ... name and password for free (although donations are welcome) and ... Copyright © Scanner Master Police Scanners Corporation. All Rights Reserved. ...www.scannermaster.com/Frequencies_s/121.htm - Cached
  5. Scanner Frequencies * Scanner Resources Free Spies Online E-mail. Greetings by Spies Online. Library Articles. Link To Us ... will find police frequencies, general frequencies, scanner radio information and ...www.spiesonline.net/scanner-resources.shtml - Cached
  6. Scanner frequencies, police, fire, NASCAR, airport, Ham radio. Scanner frequency Spectrum database, including police, fire, rescue, racing ... Free US Amateur Radio Call Sign: Home. Scanner. Frequencies. Amateur. Radio. Mass Media ...www.nationalradiodata.com/help-frequencies-frameset.html - Cached
  7. free police scanner frequencies ? washington idaho montanawashington idaho montanaanswers.yahoo.com/question/index?qid=20081023025353AAVGPXU
Nov 09, 2009 | Uniden BC92XLT Handheld Scanner
Have a programable police/fire scanner and no local codes?
Hello there:
here is a couple of links that will get you to where you can find them
  1. Police Scanner Frequencies & Scanner Frequency Resourcessafe.gif Police scanner frequency page where you can find scanner frequency resources from across the net US including free and commercial databases and listings.
    www.police-scanner.info/police-scanner-frequencies.htm - Cached - Similar
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff!.avgnotice { width: 320px; font-size: 7px; line-height: 7px;}.avgimage { height: 7px;}.avgborder { border-color: #00A120; border-style: solid; border-width: 0 3px; font-family: Arial, Helvetica, sans-serif; font-size: 10px; line-height: 13px;}.avgsep { border-color: #C0A8A6 #C0A8A6 #FFFCF7 #FFFCF7; border-style: solid; border-width: 1px 0; font-size: 0px; line-height: 0px;}.avgtop { text-align: center; background: #F4FBF4 repeat-x url(chrome://searchshield/content/background_top_green.gif); padding: 0 5px; height: 30px;}.avgmiddle { background: #C3E5CA repeat-x url(chrome://searchshield/content/background_middle_green.gif); padding: 5px 10px; word-wrap: break-word; overflow: hidden;}.avgbottom { background: #00A120; padding: 10px 5px 0 10px; border: 1px solid #00A120;}.avgbottom td { font-size: 10px; color: #ffffff;}a.avgbutton { color: #0000ff; display: block; padding-top: 3px; width: 69px; height: 20px; text-align: center; background: no-repeat url(chrome://searchshield/content/click_here_green.gif);}.avgtitle { color: #00A120; font-size: 11px; font-weight: bold; margin-bottom: 8px;}.avgnote { font-size: 9px; font-weight: bold; padding-top: 5px;} --> Safe: This page contains no active threats. Explanation:
    It is safe to proceed to this page.
    Domain:
    IP Address: 207.217.125.50
    Owner:
       Name:
       Address:
       Country Code:
    Scanned on: 10/13/09 20:44:43
    (1.08 seconds to scan this page)
    Ratings are provided by AVG. Site owners please contact AVG Technologies for questions. Keep up to date with the latest AVG news and updates. Visit the AVG website.
    click here Get our most complete protection against online threats. Get AVG Internet Security today. Find out how. click here ')" id="XPLSS_389644331U1" src="chrome://searchshield/content/safe.gif" border="0" hspace="5" /> Find everything about police scanners; general police scanner info, police scanner frequencies, live police scanner feeds, police scanner websites & more ...
    www.police-scanner.info/ - Similar
  3. you can also go to police scanner live to get some local codes ok
  4. I really hope that this is verry helpfull
  5. best regards michael
Oct 14, 2009 | Uniden Radio Communications
Would like to have the police frequencies for corpus christi,texas 78412
Hello there:
here is a link that will help you find the frequencies for corpus christi ok?
  1. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff! ... police scanners; general police scanner info, police scanner frequencies, live ... Police Scanners & Accessories. Police Scanner. Audio Feeds. Police ...www.police-scanner.info
Oct 07, 2009 | Radio Communications
Want frequencies for ''lower Burrell police'' pennsylvania
Hello there here is the link for you ok?
  1. Scanner Frequencies Scanner frequencies for thousands of cities. ... Scanner Frequencies. Alaska. Alabama. Arkansas. Arizona. California. Colorado. Connecticut ...www.cityfreq.com - Cached
  2. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... If you are looking for scanner frequencies, then you have come to the right place. ...www.angelfire.com/wi/scanner/frequency.html - Cached
  3. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
  4. Scanner Frequencies & Codes Get a scanner frequency database program by email for your state (Works with Scancat) ... Mr. Scanner Trunking Database You Can Export both frequencies and ...www.bearcat1.com/free.htm - Cached
Sep 15, 2009 | Uniden BC248CLT Base Scanner
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
