We have just had a honeywell T6360B thermastat installed as our old one packed up. Now we can no longer put the heating on timed through the Lifestyle LP112 programmer.
  • Heating & Co... Master
  • 2,461 Answers
Its weird in wrong you have to change the wires round call back who ever fitted it in they shouls put this right
Posted on Apr 22, 2010
Changing a honeywell T6060 room thermostat to a T6360B. The current wires are wired as 1 Red 2 has 2 Black and Live has another Red. Which of these wires should be connected where on the T6360B?
Can someone please tell me what a honeywall t6060 for and how to use it cause if it's for the aircon so its warm as well as cool then I'll like to knw as it dosentvwork past 15 and cuts out otherwise it's just cold and hot able thanks
Nov 21, 2011 | Honeywell Programmable Thermostat Heater
Room thermostat Honeywell T6360B - gravity hot water, pumped CH
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 02, 2010 | Honeywell Programmable Thermostat Heater
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Thermastat temp "fixed" and i do not remember how to adjust it up and down.
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 01, 2009 | Honeywell Electronic Programmable...
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
Jun 25, 2009 | Weather King 10AJA2501AH Air Conditioner
Installing thermastat
any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Oct 30, 2008 | Honeywell Heating & Cooling
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
