Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
How do you defrost the freezer,? This is an upright frigidaire ?
I can not find any controls. so do I just upplug and wait for it to defrost?
  • Frigidaire Master
  • 43,501 Answers
Yes...you can hurry things up with a hair dryer or heat gun if you want to go to that extra effort...
heatman101
Posted on Apr 23, 2010
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
How do you force a affu2067ew0 freezer in to defrost
just unplug the freezer and open the door. wait until it defrost all ice.
Jun 19, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I want to know if the freezer Frigidaire has a defrosting clock
I wait a few hours and I turned it on, I wait again all night and it is getting it´s temperature. Thanks.
Sep 06, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frigidaire FFU20FC6AW7 is not freezing. sides are cool to the touch and they are normally hot. cold air blowing out about 40 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer dying
IS THE FREEZER AN AUTO DEFROST FREEZER? IF SO, IS THERE FROST BUILT UP ON THE BACK WALL? IF FROST APPEARS ON THE BACK WALL, THERE IS A DEFROST FAILURE. THERE ARE THREE ITEMS IN THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL.
THE TIMER IS USUALLY LOCATED ON THE BACK OF THE FREEZER DOWN NEAR THE COMPRESSOR IN THE CORNER. IT HAS FOUR WIRES ATTACHED TO IT. YOU CAN ADVANCE THE TIMER BY TURNING THE KNOB ON THE FACE OF THE TIMER. WHEN IT CLICKS LOUD AND STOPS THE COMPRESSOR RUNNING, IT IS IN THE DEFROST CYCLE. WAIT 5 MNUTES AND CHECK INSIDE THE FREEZER
TO SEE IF THE HEATER COMES ON. YOU MAY BE ABLE TO HEAR THE FROST MELTING AND DROPPING ON THE HEATER. IT WILL SIZZLE AND POP. ALSO, LOOK FOR A GLOWING DOWN AT THE BOTTOM OF THE BACK PANEL.
IF THE HEATER IS ON, THE TIMER IS BAD. IF NOT, CHECK THE HEATER AND BI-METAL.
IF THE COMPRESSOR IS NOT RUNNING, CHECK THE COLD CONTROL TO SEE IF IT IS GOOD. IF THE COLD CONTROL IS O.K., THE START DEVICE ON THE COMPRESSOR MAY BE BAD. DOES THE COMPRESSOR HUM FOR A MINUTE AND THEN CLICK AND SHUT OFF. IT CAN BE EITHER THE START DEVICE (RELAY) OR THE COMPRESSOR IS BAD.
Apr 02, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
115 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
