Question about LG RU-44SZ61D 44" TV
Buttons on remote and tv not working - LG RU-44SZ61D 44" TV
    New Friend:
  • 106 Answers
Change the memory ic
Posted on Apr 23, 2010
My remotes buttons don't all work, just power and volume.
If it is a universal remote, codes from a manual must be entered to make it compatible with your TV. If it is the remote that came with the TV, if you have pressed buttons which shift the device to control of the DVD or another device, buttons unrelated to TV functions may not work. Press the button which defaults the remote to control of the TV. You may wish to look for a user guide for the remote on the internet. Otherwise, you may need to contact support on the webpages of your TV manufacturer.
Nov 17, 2017 | Televison & Video
My panasonic up/down channel buttons on the side of the tv wont work
Try getting a Harmony remote control. It will operate your tv and anything else you can connect to it. When the TV gets too old to fix, the remote can be reprogrammed for the new TV, so it never gets obsolete. The remote is programmed from their website.
Mar 20, 2014 | Panasonic Televison & Video
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated...
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
Tv remote just quit working. The remote that came witht hte tv does nothing. The remote to the cable box will work TV volume but not turn tv on and off
Tv remote now,only parts of the buttons on the remote pad,work?Tries changes with new battery already?Yes,the remote CPU probally shorted or the inner rubber layer of the buttons is worn out.Try website like Remotes.com to buy the tv original remote or a very close compatible one.
May 27, 2011 | Philips 42PFL5332D 42 in. LCD Television
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Volume buttons of Sony Remote control is not working for Akai TV.
Volume buttons on Sony remote will work on Sony TV only.
Aug 04, 2008 | Sony RM-V310 Remote Control
LG RU-44SZ61D 44" TV Logo
61 people viewed this question
Computer Repairing
Computer Repairing
