Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
34XBR800 No width setting
Hi Webterra,
I seem to have done exactly the same thing as you, resetting all my settings.  In my case, there remain a couple of outstanding issues that I have not been able to resolve:
1. The width mode is missing in TV 2. I am unable to control vertical convergence on the outskirts of the wide screen.
I'd appreciate any advice on what solved your width button problem and if you had the convergence issue as well.
Thanks,
Ferey
  • 74 Answers
The Sony manual can be downloaded here for free
http://www.mediafire.com/?ixd49edyyam
ID codes from manual:
KV-34XBR800
KV34XBR800
0 ID0
89
1 ID1 255
2 ID2 239
3 ID3 107
4 ID4 203
5 ID5 243
6 ID6 126
7 ID7 25
Posted on Mar 26, 2008
How do I replace the throat plate on my Imagine serger? It seems to not want to fit and lay back down flat.
  • Set lower blade to widest width setting
  • Place differential feed on N
  • Remove Needles
  • Place back circular hole in plate onto the anchor screw(this should never be loosened)
  • Plate will set down flush
  • Reinstall the front holding screw.
  • Reset width control
  • Check lower blade height, per instruction replacement manual.
Feb 26, 2015 | Baby Lock Imagine
The picture is shifted slightly left. This is really obvious when set at narrow format - the grey bar on the left is thinner than the bar on the right
you may want to download a free manual for your exact model.
All Mitsubishi sets have 3 hidden menus:
Option Menu: used mainly for a hard reset of the set.
Circuit Adjust Menu : which will have height, width, CENTERING adjustments and many others.
Convergence adjust Menu: same as in customer menu but allows save of adjustments made.
Entry into each menu is done with the original remote and a 4 digit number code.
The reason you would want the manual is it will tell you what buttons on the remote do what once you get into the (in your case) circuit adjust menu.
Some buttons will allow you to scroll the items and others to adjust them; note also on screen will be numbers indicating the current setting of each item usually with numbers. You want that so you can if you try to center picture left or right to know what original setting was in case adjusting does not help.
I have the codes for all three but confirm actual model number and get the manual so you know in your model what remote buttons do what.
Steve SD TECH
Oct 14, 2011 | Mitsubishi WS48511 48" Rear Projection...
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hi, i have a problem with my toshiba regza, 32" about 18 months old, keeps changing screen width to 4:3 from widescreen on some of the music channels on sky! keep resetting it but still does it next...
Hi Debbie,
Check the picture format setting on your Sky box.
Press Services.
4 for set up.
1 for Picture.
Theres and option that says 16:9, 4:3 or 4:3LB, make sure its set to 16:9.
Then go to Save settings and press the Select button to save the setting.
Regards
Andy
Jun 26, 2008 | Toshiba Televison & Video
34XBR800 width and convergence issue after memory reset/copy
I would love to know the original problem, and what you did exactly so far. If you change any data I suggest you write down the original numbers, or the set may become unfixable. If you check the data use the 4 key to start at the bottom and confirm that the ID codes are correct for this model. (ID1 = ID2 = ect)
You can download the complete Sony manual with this link I made, and open it with any Adobe PDF viewer.
http://www.mediafire.com/upload_complete.php?id=zmfqng4zjzy#
Mar 24, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Ingenuity-needle hits pressure foot when zigzag stitching
Reduce the width of the zig zag as a short term fix, but it seems that you either have the incorrect foot attached, or the ZZ width setting needs adjusting.
If, when the needle is set to be centred, is it actually slightly off-centre ?? You may do worse than have a service done, explaining the issue you face as well as a general go over.
As this was posted some time ago, I hope it has been resolved for you.
Mar 17, 2008 | Singer 7436 - INGENUITY
Correct overscan on kv-34xbr800
With TV off, enter the following on your remote:
Display > 5 > Volume + > Power now you are in service mode 2 & 5 will take you up and down categories 1 & 4 will take you up and down settings within categories 3 & 6 will change the data up or down
So press 2 until you come to the 2170D_2 category Press 1 until you get to HSIZ and change the data down to the required setting (different data registers for different width settings)
It could be more involved but this might do the trick in your case. Good luck!
Fixatorre
Jan 14, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
