Question about IBM CHASSIS TOWER 00N7048
I have a tower computer that I want to donate but I do not know how to remove the memory or hard drive so that I do not send what could be personal information along with it.
    Novelist:
  • 128 Answers
Just go to the start button, all programs, accessories, and click on the command prompt. At the c; prompt in the window, type the following:
Format C:
answer all of the questions with "yes"
This will totally wipe the hard drive of all info.
If you have the original installation disks, you may want to give them to the new owners. It will make it easier to reload the operating system and drivers.
Posted on Apr 22, 2010
Why my GM5688E tower won't turn on?
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Jun 15, 2014 | Computers & Internet
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
Unpluged from tower to fix tower and plugged it back in and computer can't read it
I'm going to assume it safe to guess that you didn't perform the necessary steps to "safely remove the device" which enables the operating system to KNOW that you're not using it anymore, and kill voltage to it so that when you do yank that cord out, there's no data being sent to the drive, and there wont' be any problems. IF you did just "yank the cord" then here's your problem. More than likely, you didn't know that the drive was being written to or read from (just cause you can't see it doesn't mean it don't exist...AIR, for example) and you yanked it while data was being transmitted corrupting EVERYTHING on that drive, and even the drive itself. IF you removed it while it was powered down, and it's not recognizing it anymore, then that opens up a WORLD of new possibilities for problems, could be something with your operating system, could be something with the firmware, the driver, or many other things.
Jan 08, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
How can I delete items on my hard drive on a computer that won't even come on? I want to get rid of the computer but want to make sure there's no personal information on it.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please perform a debug on the hard disk.
This would wipe off everything from the hard disk
The below link has the steps to do the same
Please note that this debug script was created for dell systems but works on almost all hard drives
http://support.dell.com/support/topics/topic.aspx/la/shared/support/dsn/en/alt_dsn_07302457082c47eda1a8f9619885f51f?c=us&l=en&s=gen
Nov 17, 2010 | Computers & Internet
I HAVE A COMPUTER TOWER THAT THE HARD DRIVE NO LONGER WORKS. A CO WORKER WOULD LIKE TO HAVE THE TOWER AND PUT IN ANOTHER HARD DRIVE. MY QUESTION IS IS THERE ANY THING STORED IN THE COMPUTER OTHER THAN WHAT...
Only a hard drive can contain the data. Other storage mediums are CD, USB flash drive and cards. If your system has any of these, you will easily spot and remove them.
Turning to the hard drive, a computer can have more than one installed so be sure to remove each one before giving it to the other person. No hard drive means NO information stored so be assured.
Oct 06, 2010 | Computers & Internet
How do I remove the harddrive from my dell dimension 4400? I am re-cycling the computer and want to destroy the hard drive for security purposes.
First go to this page
http://support.dell.com/support/edocs/systems/dim4400/techov.htm#1101565
If you scroll down just a little, it shows how your case opens up. Lay it on its left side (right side if you are looking from the front), press in the 2 locking tabs, and lift up.
That picture shows the hard drive location. Simply remove the data and power cables from the back. Then squeeze the plastic clips on the end of the drive and slide it up and out. That's it. You can remove the rail from the drive and slide it back in if someone else may be using it.
Thanks for using Fixya.
Oct 25, 2009 | Dell Dimension 4400 PC Desktop
I want to donate my IBM ThinkPad 760XL to Goodwill. How do I remove the hard drive first?
To remove the hard disk drive:
  1. Turn the computer off.
  2. Then disconnect the AC adapter and all cables from the computer.
  3. Close the computer display and turn the computer over.
  4. Slide the battery latch to the unlocked position and while holding the latch in the unlocked position, slide out the battery pack.
  5. Remove the locking screw.
  6. Open the cover and position the ThinkPad system on end.
  7. Grasp the disk drive cover and slide out the drive.
To remove the cover:
  1. Release the cover tabs from the drive posts.
  2. Lift off the cover.
Sep 18, 2009 | IBM ThinkPad 760 XL Notebook
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
Tools & Hardware - Others Logo
32 people viewed this question
Top IBM Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an IBM Tool and Hardware - Other Expert? Answer questions, earn points and help others
