Question about Sony Playstation 3 (PS3) Console
When playing game, hear a pop ,screen then went blank found out fuse in plug blown replaced and fuse blew again . is there an internal fuse inside PS3
    Genius:
  • 1,175 Answers
Hi...
It needs a new power supply
Find out which version you have . For example " CECHxxxxx" or whatever
Then hit Ebay and find a replacement
There's one torx bit (#8 I think) screw under the cap on the top end
Then all the other screws are philips
Posted on Apr 22, 2010
I started my 7.3 let it run about 20 mins. went to leave it die.I found glow plug fuse blown replaced and blew again.
Hi, generally it is the fuel heater inside the fuel bowl. You can unplug the fuel heater on the back side of filter housing on drivers side and install the new thirty amp fuse.It should start, and keep you going. If it's cold where you are you should replace the fuel heater element. I hope this helps!
Nov 28, 2010 | 1997 Ford F350 Crew Cab
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
My MsPacman/Galaga upright has power but screen is black(blank)
I'm assuming this game cabinet was built in the 80's. More than likely, the monitor is an Electrohome GO-7. If this is the case, replace capacitor C511 on the monitor board. It has baked open due to old age. Usually, capacitor kits can be purchased for around 10 bucks, so you might want to replace all the caps on the board at ths time. Worst case scenario would be that the Flyback transformer has smoked (usually you'll see a crack on the side of the transformer), causing the horizontal output transistor to cook and also the smaller of the two pigtail fuses to blow. In this case, you would have to replace the Flyback transformer, the horizontal output transistor, and the small pigtail fuse associated with it. Remember to always discharge the second anode( the suction cup thingy on the side of the tube). It will hold a substantial charge on it. Also, if the small pigtail fuse is blown, you will need to discharge the large cap on the monitor board, or else it will knock you on your rear-end when you try to replace the blown fuse. Hopefully, you'll will only have to replace one cap. C511. If your game does not have an electrohome monitor, I can still help, if you provide the manufacturers info, such as Well Gardner model 7204, or something like that. Good luck!
Feb 26, 2009 | Arcade Ms Pac Man / Galaga Cocktail Table...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 | Ovens
Sony Playstation 3 (PS3) Console Logo
181 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
