Question about HP L1706 17" LCD Monitor
The monitor menu appear suddenly in the display and I can´t erase it.
  • 749 Answers
Usually this is caused by having your keyboard too close to the monitor and the keyboard bumps the menu button..
look at the buttons on your monitor itself. One of them should say "menu" pressing that one again should close the onscreen menu. if that doesn't work look for another button marked "exit" or an "exit OR close menu" selection within the menu itself. Use the menu button to get in the menu, use the left , right, up or down to navigate through the menu and usually the "menu OR select" button to make chnages.
Posted on Apr 22, 2010
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
Display light is dim
Hello, If you display light is dim, could be 2 reasons. 1. the Lamp(s) on the display or the Inverter (the unde supplying power to the monitor). It´s hard to determine from here without physical inspection. What you can do (because you have to either replace the whole screen or these components- not an easy task for the regular user) is connect an external monitor and press FN + F4 (twice) while you get a replacement.
If you really want to replace it yourself, just go to Ebay to get the parts and youtube on How to´s, but again I do not recommend this. This has to be performed by a professional.
I hope this helps.
May 08, 2010 | Samsung R610-64G Laptop
HP L1706 17" LCD Monitor Logo
439 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
