Question about Canon PIXMA MP530 All-In-One InkJet Printer
Joyce I have a canon mp530 i cannot connect to my computer properly what should i do? all my cable or in properly.
Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Jul 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
We are moving and need the MP530 to operate wireless and wish to buy the interface through the router; does a (say) five year old MP530 support a wireless interface?
This model printer has only an USB printer connection.
To connect this printer to a wireless network, you need additional equipment, a print server with an USB pirnter connection and then connect this printer server to a wireless router using a LAN cable.
It may be easier to purchase a new printer with wireless connectivity.
Jun 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I need help faxing, saying its incomplete
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
I have Dell computer connected to DSL service. Would like to add a Canon printer and utilize print and fax capability from printer
install the cd which came with printer and connect to printer. connect fax line to phone port on printer and usb cable to usb port on it.
Apr 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Problems with printer
try to check the USB cord between the printer and the PC if it is connected...
Mar 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannot complete download of updated driver for my MP530 printer
check your data cable which is connected to your computer and printer i think your data cable is not working try to change it
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 won't work
hii<
check either your ubs cable in good condition or not..
Sep 09, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon MP530 - "scanner error" mesage
I've some problem whit the printer and my firs check printer make only bips
Sep 17, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
