Question about Whirlpool GEW9250 Electric Dryer
How do i get the plug that connects to the sensors in the inside of the drier. when i disconnected it, the plug fell inside. so i need to take the bottom front part of the drier off, HOW?
    President:
  • 949 Answers
To remove the lower panel you will need a 1/4" nut driver or socket.
Lay on the floor and look at the bottom lip of the bottom panel, you will see 2 screws with the screw heads facing you. Remove those and pull the panel down and out toward you. The sensor plug will be on the right side near the top of the opening you just created.
BE SURE TO UNPLUG THE DRYER FIRST!!!
Posted on Apr 24, 2010
I cant seem to get the timer to do anything on my excercise bike
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Apr 27, 2015 | Body Sculpture Bc1510 Exercise Bike
ZWD 1662 W start/Pause button flashing but not connecting to programme
hi,if this is the washer drier type try this,unplug m/c!! take lid off and locate the four connections to the drier unit near the back panel.some connections will be double tagged others single tag.disconnect all four connections and let wires dangle down a bit ,they shouldn`t touch anything.plug m/c back in and try a program such as drain and spin,and then if ok try a fill.the reasoning behind this is that the drier element goes faulty and gives a false reading to the control pcb.if this is successful ,replace the drier element.another option if any of that doesn`t work ,check carbon motor brushes.
Jul 22, 2014 | Washing Machines
Bike will not fire
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
8. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
10.. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
11. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
12. Faulty neutral, clutch lever, or kickstand safety switch.
13. Faulty fuel pump fuse or relay.
14. Tilt sensor needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
06 RSV Won Run
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
YAMAHA XVZ1300A Owner Manual
Apr 01, 2014 | Yamaha Royal Star XVZ 1300 A Motorcycles
How do you remove the accumulator from a 97 mercury mountaineer
Hi, welcome to FixYa.com my name is Shawn and I will be answering your question.
Suction Accumulator/Drier
Special Service Tool(s) st1227a.gif Spring Lock Coupling Disconnect Tool (3/4 inch)
T85L-19623-A
Removal
  1. NOTE: Replacement of the suction accumulator/drier is not required when repairing the air conditioning system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the suction accumulator/drier.
    Recover the refrigerant; for additional information, refer to Section 412-00 .
  1. Disconnect the A/C cycling switch electrical connector.
  1. NOTE: Use a back-up wrench to avoid damage to the tubes.
    Disconnect the suction accumulator/drier to A/C evaporator core fitting.
  1. Use Spring Lock Coupling Disconnect Tool (3/4 in) to disconnect the A/C manifold and tube from the suction accumulator/drier (19C836).
  1. Remove the suction accumulator/drier.
    1. Loosen the screw from the mounting bracket.
    1. Lift the suction accumulator/drier out.
  1. Drain and measure the oil from the suction accumulator/drier; for additional information, refer to Section 412-00 .
  1. Transfer the A/C cycling switch (19E561) to the new suction accumulator/drier.
Installation
  1. NOTE: Lubricate the new O-rings and install the correct amount of new PAG Compressor Oil F2AZ-19577-AC or Motorcraft YN-12c or equivalent meeting Ford specification WSH-M1C231-B to the new suction accumulator/drier.
    To install, reverse the removal procedure.
  1. Evacuate, charge and leak test the refrigerant system; for additional information, refer to Section 412-00 .
  1. Test system for proper operation.
I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 09, 2011 | 1997 Mercury Mountaineer
I need to reconnect my radiator in my 2000 ls v8
For 2000 Lincoln LS 3.9L SFI DOHC 8cyl...
Radiator - Removal & Installation
  1. Drain the engine cooling system.
  2. Remove the upper radiator sight shield.
  3. Remove the air cleaner outlet tube.
  4. Remove the six bolts and the two radiator upper support brackets.
  5. Remove the upper radiator hose.
  6. Remove the bolt and position the receiver drier aside.
  7. Disconnect the dual flow coolant valve electrical connector and the A/C line from the fan shroud.
  8. 3.0L engines only:
    Disconnect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  9. Remove the bolts.
  10. Remove the bracket.
  11. 3.9L engines only:
    Remove the bolt and position the electric water pump aside.
  12. Disconnect the high pressure cooling fan bracket and line.
  13. Inspect the seal and install a new seal if necessary.
  14. Disconnect the return hose from the cooling fan and shroud.
  15. Separate the return hose from the fan shroud and position aside.
  16. Remove the two bolts and the fan shroud assembly.
  17. Remove the A/C condenser.
  18. Remove the two bolts and position the multi-cooler assembly aside.
  19. Remove the bolts and the condenser support brackets.
  20. Remove the radiator.
To install:
  1. Install the following:
    Radiator Condenser support brackets Multi-cooler assembly A/C condenser Fan shroud assembly
  2. Connect the return hose to the fan shroud
  3. Connect the high pressure cooling fan bracket and line.
  4. 3.9L engines only:
    Replace the bolt and position the electric water pump aside.
  5. 3.0L engines only:
    Connect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  6. Replace the following
    The upper radiator sight shield. The air cleaner outlet tube. The six bolts and the two radiator upper support brackets. The upper radiator hose. The bolt and position the receiver drier aside.
Hope help with this (remember rated and comment this).
Mar 17, 2010 | 2000 Lincoln LS
1996 cherokee sport 6 cylinder manual trans. looking for a replacement wiring harness for an 02 sensor near my cat. converter.. the harness has 2 connectors on it to my knowlege, both are near converter,...
Likely the quickest way to find one is at a scrapyard. Next and likely only other option is to order one from a dealer. Before installing, check the connections to make sure that wiring attached inside the remaining plug is still connected.
Sep 15, 2009 | 1996 Jeep Cherokee Sport
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is sparking
first turn the breaker off like now pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front that will let you replace the screws
Mar 28, 2008 | Dryers
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
