Question about Kenwood 50W x 4 MOSFET Apple iPod /SIRIUS/HD Radio-Ready Marine CD Deck
Where does the blue wire on my amp connect to the head unit ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Connect it to the blue and white wire on the head unit if it has two blue wires. if only one blue wire, use that one.
Posted on Apr 23, 2010
Problem w/ my xplod amp
To wire correctly, I have the same xplod amp in my car.
Phono leads connect to the output terminals on the back of your head unit, Then connect to the input terminals on your amp.
The remote wire connects to the amp remote wire behind your head unit (if don't have a wire labeled amp behind the head unit then it usually a blue and white wire).
The power lead from your battery connects to the 12v or PWR terminal on your amp.
Then the Ground wire connects to a rust, dust and paint free area on your car (bolted down), Try behind your rear seats and find a bolt already there. This wire then connects to the GRND terminal on your amp.
Hope this helps.
Feb 03, 2013 | Car Audio & Video
Blue wire on new car head unit
its just for the amp remote it goes no where unless you have an amp
May 18, 2012 | Car Audio & Video
How to i install a Pioneer DEH-1250 to a Jensen 5500?I got these as a gift and its like confusing me.Please help me out and send me a diagram on the input wiring from the Pioneer player to the Jensen 5500-...
Hi, what you want to do is just connect the speaker wires from the head unit straight across to the pre-amp inputs of the amp. If you have a sub, also connect the pre-amp outputs of the head unit to the 2 sub inputs of the amp. Connect the blue wire of the head unit to the turn-on terminal of the amp and connect power wires to both units. May I ask what speakers are you using?
Aug 14, 2011 | Jensen Car Audio & Video
Im trying to wire an amp remote wire huh
the blue or blue with white wire. 1 is for the amp and the other is for a motorized antenna try either 1, you can not short any thing by hooking up the wrong one
Apr 25, 2010 | Car Audio & Video
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
Power off issue
Hello octoberburni,
No it is not normal for the amp to stay on when you turn the ignition off. And yes, it will definitely drain your battery if this condition is not corrected.
Use a multimeter set to volts and check between the ground connection (right connector) and remote turn-on connection (center connector) on the amp itself. You should have approximately 12V when the ignition and your head unit is on. And 0V when they are off. If you measure voltage when the ignition and head unit are off, either the incorrect wire is connected to the remote terminal, or the defect is in your head unit. If you measure OK, that is voltage present when ignition and head unit are on, and no voltage when they are off, then the problem is most likely in the amp itself. If you find voltage on the remote wire all the time, check to see that it is coming from the correct output from the head unit. Most aftermarket head units use a blue or a blue/white wire for the remote amp turn-on lead. Many (most) stock OEM receivers do not have a remote amp turn-on lead. But they may have a power antenna lead which will serve the same purpose. In any case, just insure that the correct wire is connected to the amp. It should have voltage when the head unit is on and no voltage when the head unit is off.
In either case, if everything else is still working with the amp, you can simply wire in a manual toggle switch to turn the amp off or on whenever you desire. A SPST (single pole-single throw) toggle switch is what you need. If the problem is in the head unit wire, put the toggle switch inline with the remote wire and mount it somewhere handy on or near the dash. If the problem is not in the remote wire, you'll need to put the toggle inline with the main power wire, the one marked "12V" (left connector) on the amp. In this case, you need to make sure that you have a heavy duty toggle switch, one that will handle more amps than your primary fuse. You may need to look under the hood for the fuse to check it's value.
Hope this helps.
Apr 18, 2009 | Car Audio & Video
Fan on amp runs constantly. will this drain my battery?
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Aduz
Mar 22, 2009 | AudioBahn A2002T Car Audio Amplifier
A Dual car cd player'' remote wire ''blue''
Run ur remote wire to the head unit from the amp its blue and u said the head unit u have is a duel it should have a yellow wire or or a dark blue one. hook up the remote wire to one of those and let me know if that works and one more thing do not run the RCA cables on the same side of the car or truck what ever u have but if ur power wire and the remote wire are on the left hand side run ur RCA'S on right from the head unit to the amp.
Apr 04, 2008 | Car Audio & Video
Amp
The remote wire from the amp is connected to a blue wire behind your head unit. This is a power antenna activation wire; it's only active when the tuner is selected. Switch the remote wire to a blue/white wire at the head unit.
Jun 20, 2007 | Sony XM-D6000GTX Car Audio Amplifier
Amp turns off when head unit is playing cds
Connect the remote turn on to the blue wire w/white stripe coming from the head unit, NOT the solid blue wire which is the antenna turn on.
Oct 28, 2006 | MTX Thunder 421D Car Audio Amplifier
Kenwood 50W x 4 MOSFET Apple iPod /SIRIUS/HD Radio-Ready Marine CD Deck Logo
151 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
