Question about Whirlpool GBD307PDS Electric Double Oven
Whirlpool rbd275pdb double wall oven died during self clean
My whirlpool rbd275pdb double wall oven experienced the same problem today, completely shutting down during self cleaning. How do you get to the thermal fuse to replace it? Is there a way to unlock the oven door?
  • 3 more comments
  • cpeters Mar 28, 2008
    My problem is the same. I have an electric double oven. It is about 9 years old. We were running the self cleaning cycle and when we came back everything is dead and the oven door is locked. The circuit breaker is on. What steps should I take to resolve this problem?
    Thank you!
  • mbinder Nov 02, 2008
    I have a 9 year old whirlpool double oven GBD307PDs3. I ran the top and bottom through the self clean cycle the other day and now the bottom oven will not heat up. (Both ovens did clean). now only the top oven will turn on.
    ANy ideas?
  • Anonymous Jan 21, 2009
    No juice to the unit .Door is locked.I read that you can open it with a wire coat hanger??? How is this done?
  • gschaeff Apr 17, 2009
    My oven just died today during self-cleaning. We have managed to get it open, but where is the thermal fuse and how do you get to it?
  • Anonymous Mar 16, 2014
    F2e1 code on whirlpool double wall oven
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 1 more comment
  • Anonymous Apr 15, 2009
    I forgot to mention that the cost of the thermal fuse at Radio Shack was only $1.67........
  • Dee Slagle Jan 14, 2012
    Thanks for your help it was indeed thermal fuse
  • Patrick Jul 03, 2012
    Thanks for the help. Your explanations were perfect. You just saved me a few hundred dollars minimum if you factor in a service visit. I bought a 99 cents replacement part with the same specs and the oven is working like a champ.
    Wonder if it will survive the next cleaning cycle? If not I may upgrade for a higher temperature rating next time.
SOURCE:
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Control board is blank - door is locked
The cavity thermal fuse has blown if this happen during a self clean the TOD for the upper or lower oven has blown
Jul 31, 2014 | Whirlpool RBD245PRS 24" Double Electric...
I own a whirlpool double wall oven. The top is self cleaning but the bottom is not. I purchased this oven in early 2005. Today when I tried to use the self cleaning feature the entire oven went off but the...
Sounds Like the clock control unit may be bad, or the auto latch assy itself. I may have the part for you. What is the model number of the unit?
Sep 15, 2010 | Whirlpool Ovens
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
We had a power outage today during the self cleaning process of our double oven.. The Electronic Oven Control panel is dead. No lights of any kind. The circuit breaker is ok. Upper door is locked.
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
Dec 20, 2008 | Whirlpool GBD307PDS Electric Double Oven
Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Jun 10, 2008 | Ovens
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
1,432 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
