Question about Frigidaire GLER341A Electric Dryer
My fridgidaire dryer model FDR336RDS2 seems to run too hot
My fridgidaire dryer model FDR336RDS2 seems to running the heat to hot, the back is hot to the touch and it has left brown marks on the some clothes. how do i adjust the heat or correct the problem?
    President:
  • 949 Answers
Over heating in a dryer is almost always due to an air flow problem. Typically it is in the venting.
- Check the vent from the dryer to the wall by removing it and cleaning out, make sure there are no kinks or tears in it.
- Run the dryer once it is connected and feel outside to see if you are getting the same airflow outside as you can at the outlet of the dryer, if the air flow feels weaker outside your vent is restricted and you need to have it cleaned.
- If these are ok check your lint filter, softener residue can plug up the screen so air has trouble flowing trough it, you can wash it out with a brush and hot water
- With the lint screen out take a flashlight and look down the chute, if you see lint in there take a brush and vacuum and clean good
Posted on Apr 24, 2010
Dryer is turning but not getting hot
what's the brand name of the dryer and send the model number,if it's gas does the ignitor glow orange but no flame,also if it's gas when you start it you should hear a click,if you don't most likely the dryer is clogged with lint or the vent line is blocked with lint and the high heat popped the thermal fuse,but let me know what you have
Jan 24, 2014 | Frigidaire 134844410 Fridgidaire Dryer...
Fridgidaire dryer gallery series gets too hot too fast
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 17, 2011 | Dryers
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Frigidaire GLER341A Electric Dryer Logo
189 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
