Question about HP Photosmart C5180 All-In-One InkJet Printer
New color cartridge installed but still does not recognize it. Asks to print Black only?
  • 619 Answers
SOURCE: printing problem
your printer need head cleaning /
1. Nozzle check monitor the exact color to print / if one of the color missing or line color the printer head ned cleaning ,.
2. Proceed for head cleaning /press head cleaning
3.Nozzle check again after the color complete /test print w/picture
Posted on Jan 07, 2008
sauruman
  • 7 Answers
SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Posted on Feb 21, 2008
daveywhite
SOURCE: my printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Posted on Nov 11, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
My MFC-430W wont recognize color ink cartridges
Faulty Sensors or Cartridges if they are compatible
Sep 14, 2014 | Brother MFC Office Equipment & Supplies
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Tip
How to replace a brother catridge.
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the cartridges is empty or near empty, the printer will tell you to replace that ink cartridge.
You can buy the cartridges individually, or you can buy a pack of all three color cartridges or a pack of two black cartridges. To replace one of the ink cartridges, follow the steps below.
All four of the cartridges are located on the right front side of the printer, behind a gray plastic cover. Pull the cover forward from the side, where there is a slight cutout for your finger to grab. When the cover falls forward, you'll see the four ink cartridge holders, coded by color.
For the ink cartridge that you need to replace, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop out toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right, they go black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once the cartridge is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place.
If you are replacing more than one color, repeat this procedure for each cartridge. Then, when you are finished, close the ink cartridge cover.
If you were out of ink or low on ink, the machine should recognize the new cartridge and perform the calibration process. If it doesn't automatically recognize the new cartridge, it will ask if you have changed one or more of the cartridges. Press "1" for Yes when it asks about a color that you replaced, or "2" for No if it asks about a color you didn't replace.
Once the printer comes back up to the ready state, print a color test page to verify that everything is working. If the test page comes out okay, the new cartridge is fine and you can either discard the old cartridge in the trash or save it to recycle. (But don't get rid of it before you are sure that the new cartridge is recognized and working correctly.)
on Jul 21, 2010 | Office Equipment & Supplies
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
All colors print only black does not print. New
reset your print option set automatic or color select
Aug 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer does not recognize new color cartridge
Make sure you have taken the orange tape off the print cartridge.The printer will not recognize the cartridge with the tape on
Mar 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
hello..
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
