My power supply board shorted out and im trying to find out how much a replacement supply board will cost for my delta 1010
  • Graeme Ross
    Graeme Ross May 11, 2010
    Is it an M-Box delta1010?
  • 1,512 Answers
Hi, do you still need a hand with sorting this out?
regards
Graeme
Posted on Mar 31, 2008
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
TV won't turn on. When I try to turn it on it quickly turns back off.
its the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop, but if otherwise
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps.....
Jul 30, 2010 | Insignia NS-LCD47HD-09 47 in. LCD TV
Where can i get a free M-audio 1010 to download?
You can download the Delta 1010 drivers from the website http://www.m-audio.com/index.php?do=support.drivers&f=736
I hope this works for you :)
Regards,
Aby
Apr 21, 2010 | M-Audio Delta 1010 Sound Card
Cant get sound
see your m powerd out put.
Apr 04, 2010 | M-Audio Delta 1010 LT Sound Card
Popping and clicking in delta 1010 playback
frequency response: 20Hz-22kHz, +/-0.3dB spacer.gif dynamic range (A-weighted): 109dB (A/D), 117dB (D/A) spacer.gif signal-to-noise ratio (A-weighted): -109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
Jul 22, 2009 | M-Audio Delta 1010 Sound Card
M-Audio Delta 1010 PCI CARD
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Jun 17, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Using drum triggers with M Audio Delta 1010 and Digidesign MP 7.3
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
May 14, 2008 | M-Audio Delta 1010 Sound Card
Clicks
try to change the clock sync in the sound card to independent
Mar 26, 2008 | M-Audio Delta 1010 Sound Card
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
Loud buzz on every output with no audio
Look in the computer music mags and look fro M-Audio dealers. Ring them up and tell them the problem your having and see how much it will cost to fix. If it's humming then it's proably broke and needs repairing. Just make sure the sampel rate isn't set too low as well
Dec 26, 2006 | M-Audio Delta 1010 Sound Card
48 people viewed this question
 Grubhead
Grubhead
