Question about Dell 1600n All-In-One Laser Printer
Went from PC to Mac and can't get my Dell 1600n to work.
5 Suggested Answers
SOURCE: Driver for mac OS for Dell 1600n
the Dell 1600n is indeed a re-branded Xerox PE120. I did a search on that model and "OS X" and found the appropriate driver on the Xerox website. Loaded it and it works like a charm.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=PE120_PE120I&Xlang=en_US&Xcntry=USA
Posted on May 08, 2008
  • 7 Answers
SOURCE: Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Posted on Nov 10, 2008
vegakitten20
  • 685 Answers
SOURCE: DELL 1600n drivers for 2003 Server (Network Scan)
  1. Click the file name below to download the driver:
    R165289.EXE
    new_note.jpg Note: By downloading, you accept the terms of the Dell Software License Agreement.
  1. Click the Save button.
  2. On the Save As: window, verify that the R165289.EXE file name is listed in the File name: box, and then click the Save button.
  3. On the File saved window, click the OK button.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Posted on Nov 26, 2008
  • 22 Answers
SOURCE: dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Posted on Mar 16, 2009
Does the dell 1600n have a battery?
Yes a tiny one, but is only for storing time and other settings in the NVRAM.
It can not power up the printer.
Feb 19, 2013 | Dell 1600n All-In-One Laser Printer
Have got new pc driver for Dell 1600n needs to be installed
Here is the link from Dell Official Support for Drivers download for Dell 1600n
Select Operating System and get the drivers and software.
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
Dec 16, 2010 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Mac compatible with Dell All In One 924 Printer
Unfortunately, there is no offical driver for Mac OS X for this specific printer, but you can try following this link to see if the steps there can at least help you try to use the printer under that operating system. If it does, great, but if it doesn't, I'm afraid you're out of luck
May 10, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n Scanner bulb doesn't light up
Scanners, when broken, are irreparable. (or at least thats what I was told when I worked for Dell)
Feb 01, 2009 | Dell 1600n All-In-One Laser Printer
Printer Driver for Mac
Called Xerox, they we able to make it work on their Mac, same version of Leopard etc.  Called Apple they discovered that Firefox was the problem and told me to download the driver with Safari.  Bingo, it worked.
May 29, 2008 | Dell 1600n All-In-One Laser Printer
If you install the Xerox1600n it should work for you. That is what we had to do.
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
No power
Try it in another powerpoint. Try uninstalling it and reinstalling it on pc if not a stand alone unit. Could be the power support has died and may need repalacing.
Aug 16, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
19 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
