Question about HP OfficeJet J4580 All-In-One Laser Printer
Paper jam do not know how to fix, or how to open printer to fix jam
  • 52 Answers
Put off the printer. Open the back assembly(two buttons on the side of it) You will see the paper, pull it out very gently.
Good luck
Posted on Apr 24, 2010
How do I fix a printer error
turn the printer off..then after a while it turn back on, the jammed paper will come out automatically if it doesn't pull the paper towards you not the other way pull it forward until it is totally outside the exit tray.. dont pull it on the feeding unit cause it will damage the feeder unit and the paper might tear apart leaving a piece of it inside that would be more difficult cause you have to open the entire printer unit.
Oct 02, 2014 | Canon PIXMA Office Equipment & Supplies
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Can't see Paper jam
Open the top cover to see the jammed paper. If u wont see the paper then you have to open the cabinet of the printer . After opening remove the paper
cheers
Jun 23, 2009 | Lexmark X2470 All-In-One InkJet Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
My school's computer "Lexmark E323" has a paper jam and nobody knows how to fix it
hi!!!!try to open the duplexer at the back of your printer and see if there's a paper stock in the duplexer who cause a paper jam to your printer.
May 01, 2009 | Lexmark E323 Laser Printer
Paper is jamming all the time
You will need a tech guy to fix this. Sorry to dissapoint
Apr 27, 2009 | Panasonic KX-MB781 All-In-One Laser...
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper jam. When I use my printer paper is jam and goes at a wrong angle. Please. Let me know how I can fix of it. Thanks. Valeriy
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
Paper jam
Hi Marybarron,
Please visit the below mentioned link, if you want to know:
How to fix the Paper Jam problem
Also, you will find the opening instructions on that page itself.
Thank You
Oct 16, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
