Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have the Lawn Tractor PO17542LT, which needs the seasonal maintenance of replacing the spark plug and fuel filter. It started once this year, after i replaced it with a new battery. Now it won't start, or turn over. I am a novice and tried to look for instructions in the manuel on how to replace these parts. I could not find the information. It assumes that you should already know these things. Where are the locations of spark plug and fuel filter to replace? Where can i find how to instructions. I don't want to take the mower to a repair shop, because i do not have a trailer to haul the mower with. Thank you very much for information.
    Master:
  • Poulan Master
  • 645 Answers
This model only has 1 spark plug. It is on the front of the engine, follow the plug wire to find it. The fuel filter is between the fuel tank and carburetor. If a new battery does not start the unit (first check the battery) you probably have a bad fuse. Located on the back side of the ignition switch. Trace the red wire and you will find it.
Posted on Nov 20, 2017
  • 10 Answers
SOURCE: what makes my poulan 15.5 lawn tractor back fire
TYhe valves need to be adjusted
Posted on Jun 01, 2009
  • 25 Answers
SOURCE: briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Posted on Jun 23, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
10 year old Craftsman Lawn Tractor won't start
That's really strange. The low-speed fuel adjustment screw may be set way too rich, but that doesn't seem likely. With the air filter off, look at the choke plate if possible as you advance the throttle and see at what point the choke closes. Back it off till the choke opens and then put the filter back on and try to start it at that setting. Another thing that could cause too much fuel is if the adjustment of the carburetor float is off, causing the fuel level to be too high in the carb bowl.
Aug 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Jul 03, 2009 | Garden
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
94 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
