Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
I need information about the memory kind and maximum
    Novelist:
  • 128 Answers
It requires DDR Ram, max 4 gigs, speeds of DDR400 OR DDR333.
GO TO http://en.kioskea.net/guide/details/220043-intel-d915gag
Posted on Apr 22, 2010
Compatibility konica minolta z20 with sd memory card
The following link has a wealth of information about the camera including type of SD card suitable for this model
http://www.imaging-resource.com/PRODS/Z20/Z20A.HTM
Apr 12, 2014 | Konica Minolta DiMAGE Z20 Digital Camera
I want to upgrade my memory for a Gateway 310x PC Desktop. What kind of memory and what is the maximum memory I can buy?
It will be having two memory slots.So you can upgrade maximum up to 2GB. You need to use DDR SDRAM with a frequency of 333MHz
Aug 28, 2010 | Gateway 310X PC Desktop
Q:/Max. RAM Memory & MHZ supported
hi there,
You can find your required information about memory here, at the bottom of the page under the System Information tab.
http://www.memory-up.com/Memory_finders/DesktopSelector.aspx?modelId=14541
Thanks
May 25, 2010 | Computers & Internet
RAM compatibilty
No, DDR 400 will not work. The best thing you can do is call Dell and give them your information. Model number and that kind of information and let them tell you what kind of ram you need. If you put the wrong type of ram in your machine it could cause major damage. There are so many different kinds of memory out there, not to mention high and low denisity. Your machine may use PC2700 high density and if you try to use PC2700 low density it will not work. One other thing that you can try is uninstall a stick of your ram and write down everything on the stickers and then go to some place like kingston memory and use their memory locator to find what you need.
Dec 01, 2009 | Dell Dimension 2400 PC Desktop
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Upgrading the ram memory
Your english is very good :c) This link here will show you everything you need to know about the memory for your computer. Basically, 2 GB maximum of DDR2-PC2-5300. I do not know if they ship internationally or not but if you write down the specifications I'm sure you can get it locally. Oh and another thing if you could kindly give this solution a fixya rating, I'd appreciate it. Thanks! :c)
Jan 01, 2009 | Acer Aspire 1640Z Notebook
I dont see what kind of ram for fx6710-01 at newegg could you tell me what kind ie. pc 800 pc 1066 ??
go to www.crucial.com and run the memory utility. It will let you know what kind of memory you need and the maximum memory your computer will hold along with how many slots
Dec 06, 2008 | Computers & Internet
RAM memory: upgrade , Motherboard PCCHIPS M863 2 slot
Memory Support
• Two 184-pin, 2.5V DIMM sockets for DDR SDRAM memory modules
• Supports DDR333/266 memory bus
• Maximum installed memory is 2GB
This is what your looking for
Nov 01, 2008 | Computers & Internet
Ram memory
I recently upgraded the memory in a Gateway desktop with a similar configuration as your. If you only had two of the four memory slots filled before you attempted to upgrade, those two originally used slots must be filled first before you add memory to either one or both of the other two slots. As far as the maximum amount of memory that can be used in each slot, I would need more specific information on your computer. My suggestion at this point is that you either refer to your manual if you have one, or if you do not have a manual, you can access this information online. I was just on Gateway's web site but for your specific information on memory upgrade I would need either a more accurate model number or, what would be best is the serial number of your machine. You seem to be fairly knowledgeable about computers so the easiest would be for you to access Gateway's web site. Once you are on their site go to "support", then go to "my support". You will be prompted to enter your serial number at this time. This page should give you all the information that you need. Listed there should be the maximum amount of memory for the system and also the maximum amount of memory per slot. For example, if the maximum memory of the system is 4 GB, the maximum per slot would be 1 GB. The easiest for you, and what I did on my recent upgrade, would be to leave the existing two pieces of 256 MB in their original slots and purchase two more, 1 Gigabyte pieces and use those in the previously unused slots. You would be under the maximum that you could use in your system but adding 2 GB will improve the performance a great deal and you would not waste the memory that was originally installed.
Sep 28, 2008 | Gateway 510 X Peak Performance (510XPP) PC...
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
