Question about Vestax Pmc06proa Thin DJ Scratch Mixer System
My vestax pmc 06 pro a will not power on - Vestax Pmc06proa Thin DJ Scratch Mixer System
My vestax 06 pro a with problems suddenly fall a chanel or down 1 chanel,left chanel in phono.and i beat him and the chanel back and down again.i replace all rca contacts,cable..xcuse me for my bad english!!!
Posted on Jul 22, 2010
  • 22 Answers
Get a multi meter and check the power supply
Posted on Apr 25, 2010
4 Suggested Answers
SOURCE: vestax pmc-o5 pro 2
probably just a cold solder joint on the power plug inside the mixer. Check with a meter, then repair(resolder) if needed.
Posted on Mar 09, 2009
SOURCE: vestax pmc 06 mixer / Virtual DJ Mix station
you need a sound card with headphone out seperate from master out
Posted on Mar 29, 2009
  • 16 Answers
SOURCE: the headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Posted on Aug 30, 2009
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
Power cord get really hot.
If mixer is working properly, check the rating of the adapter versus what the unit requires. Some sites indicate this requires a 12 volt adapter rated at 1.2 amps.
Feb 08, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
Need to change the fuse in a vestax pmc
Sorry, since the mixer is powered by a "wall wart" adapter, it is UNLIKELY there are fuses in the unit.
If it is inoperative, then check the voltage of your power adapter. If you by chance connected a wrong adapter, try the correct one. It is possible damage was done in this case that is not so easily fixed as changing a fuse. The correct adapter looks to be a type AC14 which LOOKS to be a 15 volt DC, 500 ma, with negative on the pin.
Jan 25, 2010 | Vestax Pmc 280 DJ Mixer
My Power supply keeps blowing out
Sir,
You are suggested to buy power stabilzer because some the thing which blows the power supply is unbalance voltage. which Power stabilizer resolve . hope fully this would work.
Aug 30, 2009 | Vestax Pmc05pro-Sl 2-Channel DJ Mixer...
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Vestax pmc-o5 pro 2
Nov 24, 2008 | Vestax Pmc07pro DJ Mixer System
Vestax pmc 06 mixer / Virtual DJ Mix station
Oct 19, 2008 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Vestax Pmc06proa Thin DJ Scratch Mixer System Logo
630 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
