Question about Black & Decker B2300 Bread Machine
Rotating shaft does not turn.
What could have caused the shaft to freeze in this way? How can I fix it?
How to fix a rotating shaft that keeps falling out
a rotating shaft in what
need make model year , type of equipment, work done etc
post again as posts are not linked
Jan 10, 2017 | Cars & Trucks
Seized up motor, overheating
Does the handwheel turn freely. If hard to turn then I suspect the main bearings need to be freed up and relubricated. A sewing machine has a rotating shaft something like an engine crankshaft with a front and rear bearing to hold it in position. Various other "cranks" attach to this rotating shaft. From the various problem reports I've seen and from having my own machine freeze up, it appears this Viking model family is prone to this problem after some number of years of use. The motor overheating is simply the side effect of the problem.
Dec 29, 2012 | Husqvarna Huskylock Computerized 910
The 2 rotating parts in the front that the snow is sucked into the machine, only half of it is rotating the other is not moving at all this causes the snow to pile up in front. whats missing or broke?
There is a shear pin that is broken.it looks like a bolt that is designed too break if you hit something that is hard and won,t break up.while it is not running rotate the side of the auger that is not turning untill the holes in the auger and the shaft line up then put new shear pin through auger and shaft.
Dec 27, 2010 | Garden
Refrigerator is freezing my produce items (veggies&fruits) Freezer side is thawing and ice is melting waterfalls over and down all other levels. Freezer & frig. settings have always been set on...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 10, 2010 | Kenmore 25.1 cu. ft. Side-By-Side...
Could a rearaxle leak cause my reverse not to work on my 2000 chevey blazer?
reverse is controlled in your transmission, the rear diff is responsible for changing the rotating motion of the drive shaft into directional rotational motion to turn your axles
Apr 07, 2010 | 2002 Chevrolet Blazer
I need to take the pulley off from under the motor so I can change out the belt.It keeps turning how do I lock it down.
Use a pair of Vice Grips, or similar, and grab the shaft behind the Pulley if possible and "Lock" it against something to stop it rotating.
Mar 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
The belt on the radome drive sprocket jumps off of
The belt pully on the motor has a set screw that tends to get loose causing the pully to change position on the shaft. Position the pully on the shaft (move up or down) for better alignment with the pully on the rotating array pully and tighten the set screw..
Feb 23, 2009 | Furuno 2.2kw 18" Radome
Back to Basic Smoothie Freeze Bades don't rotate
check to see if you can move the blades by rotating the shaft on the bottom of the goblet, sounds like you need a new blade assembly.
you can order the part from their website:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
Jun 02, 2008 | Back to Basics 600 Smoothie Plus Work Top...
Ice Maker problem
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
Nov 16, 2007 | KitchenAid KSCS25IN Side by Side...
Black & Decker B2300 Bread Machine Logo
20 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
