No audo device
No sound
for xp
    Scholar:
  • 82 Answers
Please follow the following steps to rectify this problem :
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the PC on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most PC's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
Some computers come with sound on the motherboard (on-board), and some computers use a sound card. The on-board sound setting in the BIOS has to be set according to your particular sound configuration. Perform the following steps to correctly configure the sound in the BIOS:
Look at the back of your computer and use one of the following three items to determine the proper sound configuration and sound setting:
If the plugs for the speakers and microphones are located next to the parallel, serial, or USB ports, then the computer has on-board sound. The on-board sound setting in the BIOS should be Enabled. If the plugs for the speakers and microphone are located away from the other ports and sit in an area by themselves, the computer has a soundcard. The on-board sound setting (if there is one) in the BIOS should be Disabled. If the computer has sound plugs in both locations, a
soundcard has been added to the computer that already contains on-board sound. The on-board sound setting should be Disabled. To enter the BIOS, turn on the computer and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If your computer came with a motherboard CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Posted on Apr 22, 2010
My laptop has no sound
is it is on xp and you have formatted it? if so you will need to reinstall the audo drivers
Aug 08, 2011 | Computers & Internet
Have windows XP. Somehow audo is out.Did I accidently switch isit off?
Yes, you might have turned off the sound in your PC.
For Windows Xp this is the procedure to turn it ON.
Go to 'Start'--->Settings---->Control Panel----->Sounds and Audio Devices
Here you will get a window where you will find all the sound related options.Here you will beable to modify the volume levels and check whether the mute checkbox is ticked, if yes then uncheck the box and click on OK.
your problem should be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Apr 13, 2011 | Computers & Internet
Volume is gone....tells me no audio found
Try switching audo devices in control panel. If that doesn't work you must use system recovery disks provided when you bought your laptop.
Oct 30, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
I want to download conexant hd audio 221 xp c770tu diver how can
The headphones would not be the issue unless they came with an actual software cd included. If your audio Drivers are not the correct ones for your audio device on your computer, download the proper ones. Best way to find out what you have is to look under Device Manager which is in Control Panel, Under the System>Hardware Option in the Control Panel Folder.
Verify that your device is working properly. If it is working properly. and All other audio options, like Speakers work, then the Headphones are malfunctioning and you will need to contact the manufacturer.
If no audo works at all but the Device is listed as working properly, then you possibly have a damage audio jack port
Jan 20, 2009 | Audio Players & Recorders
Audio problem
hey man!..check the physical volume control down in your laptop..or Fn+ volume control key..if not available..or still same problem..try to re install the sound driver...
Jan 04, 2009 | Dell Inspiron XPS M140 Notebook
I have no audio sound at all. I believe I deleted some sort of program from my computer by accident. How can I get back the audio sound on?
Just check the audo controls in control panel ... goto sounds and devices!! You might have muted it by mistake!!!
Jun 15, 2008 | Computers & Internet
Hii
Board ECS elitegroup NO SOUND
windows XP must not include the drivers for your audio devices. check on the manufacturer's site for the windows XP audio drivers.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
