Question about Lexmark X2500 All-In-One Printer
Incorrect Port detected
The current print job has been cancelled. The computer is designed to work with USB cables only The current software is not set to USB port.
Agent Blue
  • 39 Answers
SOURCE: Hi. I have previously downloaded the
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Posted on Aug 07, 2008
yboyandrei
  • 828 Answers
SOURCE: Lexmark Z35: Problem Communicating with the
Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
Posted on Oct 04, 2009
samuelseno
  • 103 Answers
SOURCE: My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Posted on Jul 23, 2010
  • 8404 Answers
SOURCE: got a new computer supports
This printer and this software (on your laptop) want to hold hands directly ... not through a proxy. You have solved your own issue ... plug the Lex into the new computer.
Posted on Sep 27, 2010
ib_yang
  • 1098 Answers
SOURCE: My Lexmark 4800 series shows
You may want to reset your printer system by:
1. Control-click or right-click a print queue in the "Printers" pane.
2. Choose "Reset printing system..." from the contextual menu.
3. Click "OK" in the "Are you sure..." confirmation sheet.
Let us know if this helps.
Thank you for using Fixya.
Posted on Jan 03, 2011
I am getting an error message saying Incorrect port detected. The printer is designed to work with USB cables only. The current software setting is not set to USB port. In my printer properties dialog
Do you hear the connect/disconnect sounds when you plug the USB cable into your computer? If you do not, then the system is not recognizing the printer USB port.
Here is what I would do:
1. In the Devices and Printers section of the control panel, right-click on the printer icon, and select printer properties, then select the Ports Tab. Delete any ports connections for the printer. There could be several for the same printer.
2. Uninstall all Lexmark drivers.
3. Make sure that the printer does not show up in the Devices and printers under control panel. If the printer still shows up, remove the device by right-clicking on the icon, and select Remove device.
4. Reboot the computer.
5. Re-install the printer software. The software should detect the printer on the USB port.
Good luck.
Alex
Feb 14, 2015 | Lexmark X5650es All-In-One Inkjet Printer...
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
Got a new computer supports window 7 and sharing with my other computer which is the host and has the printer which is a lexmark 5600-6600 series.. when i go to print it says this incorrect port...
Sep 27, 2010 | Office Equipment & Supplies
Hello!
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
Oct 04, 2009 | Lexmark Z735 InkJet Printer
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
Hi. I have previously downloaded the driver for the Lexmark X75 printer, but when I try to print -I get the following error message: "Incorrect Port Detected. The current print job has been...
Aug 05, 2008 | Lexmark Office Equipment & Supplies
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Jun 08, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X2500 All-In-One Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
