Question about Kenwood DNX5120 DVD Navigation System GPS Receiver
Kenwood Dnx5120 maps won't load
My maps won't load anymore, when I press the NAV button, the unit switches to the blue garmin screen, but never loads the maps?? ? Can someone please help me?
4 Suggested Answers
neogil22
  • 36 Answers
SOURCE: kenwood dnx5120 no detailed maps?
hi....
Open the cd/dvd tray and close it again. it should be a disc-read fault. That can be, the disc is dirty or damaged. Hope it's only dirty.
greetings and hope it will work soon, Gilbert.
Posted on Mar 03, 2009
SOURCE: Suddenly all detailed maps are locked, I can't unlock them
I had the same problem so I went to garmin.com/kenwood and downloaded the latest update to my pc unzipped the file and burned it to a cd put the cd in my dnx5120 and updated my system and my maps came back ... read the install instruction on their web site and this should solve the problem at least it did for me ....good luck hope this was helpful to all ...
Posted on Mar 26, 2009
alpug
  • 1961 Answers
SOURCE: I have a Kenwood DNX5120
here is what you need to do.
1. go to http://www8.garmin.com/products/kenwood/
2. select and download the Software Updates for CNX5120 on your PC.
3. Unzip the file and burn it to a CD.
4. put the CD in DNX5120 and update its system.
Please read carefully the instruction on their web site.
Hope this is everything you need. Just post back if you still have question.
Please do rate this solution.
Thank you for using Fixya.
Alp
Posted on Sep 06, 2010
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
Why is my kenwood gps screen blank? but everything else works.
This question is the proverbial How long is a piece of string!
For a start the "other functions" you speak of are burned into the ROM
The maps are loaded into memory from a CD. I would assume that your maps have become disconnected and therefore either fail to load or are not setting the display
I recently experienced this on a 5120
You will need a pc with a dvd/cd writer. Go towww.garmin.com/kenwwood, and download to new firmware/software. Justfollow the instructions and upgrade your 5120's software to version2.60.
All you have to do is unzip the file on your pc, copy it to yourcd using your burner software, then load it into your kenwood's dvd/cddrive. Your maps should come back.
If they don't it will be a send to Garmin/Kenwood
Thanks for using FIXYA
Nov 20, 2009 | Kenwood DNX5120 DVD Navigation System GPS...
The detailed maps are "locked" all of a sudden!
If this is still happening then go to Kenwood direct, they supplied the unit with the pre loaded software and therefore they should deal with the problem as they are not supposed to lock the software. Kenwood if need be will contact Garmin for you. You may find that they have experienced this problem with other users too.
Jun 09, 2009 | Kenwood DNX5120 DVD Navigation System GPS...
Unlock maps
I would suggest you contact garmin for the unlock codes which you will have to purchase for your unit
Jan 11, 2009 | Kenwood DNX7100 Car Video Player
Jan 02, 2009 | Kenwood DNX5120 DVD Navigation System GPS...
I have had my Kenwood DNX5120 for 2 weeks now, and yesterday the screen just went blank while driving. You can see the colors morphing around the buttons, but none of the buttons work. You can tap all over...
I just had this problem. You will need a pc with a dvd/cd writer. Go to www.garmin.com/kenwwood, and download to new firmware/software. Just follow the instructions and upgrade your 5120's software to version 2.60. All you have to do is unzip the file on your pc, copy it to your cd using your burner software, then load it into your kenwood's dvd/cd drive. Your maps should come back.
Dec 24, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Kenwood DNX5120 DVD Navigation System GPS Receiver Logo
133 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
