Question about 2wire (2701HG-B) Wireless Router
I have a 2wire wireless router but i've had it hooked up to my airport express as the wireless router. How do i get the 2wire to function as the wireless router? only the DSL light lights up, not the wireless
  • 33 Answers
Since the Wireless light is off, lets assume that the access point is just switched off.
That function is switched on and off from the router's control panel accessible via web browser. And you can follow these steps to get to the Wireless configuration control panel.
Open this URL from your browser
http://gateway.2wire.net.
If you have a system password enabled (and it's asking for it) but you didn't set it, or you forgot what it is you can click the
can’t remember the password
link if the password hint does not help you. In order to reset the password, you'll be asked to enter a 10 digit code which you can find on the bottom of the router itself.
Once you're able to gain access to the control panel, you'll want to
  1. click the 'Home Network' tab
  2. click the 'Wireless Settings' link
From this panel you can make changes to how the wireless access point portion of the router is configured. By default your router's wireless should be on, but since it's not I'm going to assume at one point in time someone turned it off so it wouldn't get confused with your airport express. If you just want your wireless settings back to the default settings
  1. click the 'RESTORE DEFAULTS' button
Then the wifi settings will be set to how they were when the router was purchased. By default the access point is secured by WEP encryption, and the key is located on the bottom of the router by the Serial Number.
Posted on Apr 22, 2010
How to install canon mp250 printer to ipad2
as this printer has no WiFi function it cannot print directly to an iPad.
however if you have an airport-express router you can connect the printer there with a USB-cable and use it wirelessly...
install-canon-mp250-printer-ipad2-24izmgwjpqkk3mw4hcixslyy-2-0.jpg Canon Support Drivers PIXMA MP250 AirPort Express 802 11n 2nd Generation Guide to ports and connectors install-canon-mp250-printer-ipad2-24izmgwjpqkk3mw4hcixslyy-2-2.jpg
Aug 08, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Can I repair an airport express 802.11n? I bought a broken airport express on ebay ($20 incl. shipping) expecting that the power supply was the issue and knowing that I could cut the thing open and work...
I am suppose to add the solution here but unfortunately i am here to explain the problem. I got the new Airport Express. I have HP Pavillion and running with Windows Home VISTA. I tried almost here and there everything which is mentioned on forum. But it is not working.Laptop can connect with router but router is not getting connected with Internet. It's always displaying local access only which is killing me. I will try to give one more try to this setup otherwise i need to return this **** and get something else.
Sep 20, 2011 | Apple AirPort Express Base Station with...
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Airport settings in Mac leopard
Make sure your ADSL router has wireless capability or wireless function. Verify that from your Internet Provider. If your ADSL router doesn't have wireless function, you need to buy a separate wireless router then cascade it to your ADSL router, from there your airport must be working fine.
Sep 09, 2008 | NetGear DG834G Router
ISP problem with 2wire 2700HG-B
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with http://192.168.1.254/ for the system summary, from there you can set up your password etc...
May 14, 2008 | 2wire 2700HG-B Router (2700HGB)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
2wire (2701HG-B) Wireless Router Logo
517 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
